 Cleaning Rub Rail
Initially Posted - 08/18/2013 :  10:42:45  Show Profile  Visit britinusa's Homepage
Thanks to Dave Elliott,
While prepping JD for the upcoming weekend sail, I converted the tarp to a tent so we could clean her up.
The Rub Rail looked really bad.
With a rag soaked in Acetone a few quick wipes and it made a big difference, but still quite a bit grimy.
Next I tried it on a pad of steel wool soaked in Acetone. WOW!
15 minutes and one side complete, a quick rub down with fresh water and the rub rail looks about 90% better, not sure I could get rid of most of the marks left as they were... well, typical rub rail marks from coming alongside to heavy.
<center>[url="https://www.catalina-capri-25s.net/cgi-local/MBR_system.cgi?VM+1000-2153"]
Click to View Full Sized Image[/url]
<b>Rub Rail</b>
Cleaned each side of the grimy section of Rub Rail using Wire Wool and Acetone.</center>
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 08/18/2013 :  11:55:42  Show Profile  Visit delliottg's Homepage
Nice!
Peregrine
Response Posted - 08/18/2013 :  14:28:42  Show Profile  Visit Peregrine's Homepage
<font face="Comic Sans MS"><font size="3"><font color="navy">I've been using Armorall with good results. The acetone looks great. With both don't let it drip down on the hull as both will strip any wax off.</font id="navy"></font id="size3"></font id="Comic Sans MS">
Response Posted - 08/18/2013 :  16:19:28  Show Profile  Visit britinusa's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Peregrine</i>
<br /><font face="Comic Sans MS"><font size="3"><font color="navy">With both don't let it drip down on the hull as both will strip any wax off.</font id="navy"></font id="size3"></font id="Comic Sans MS">
Agreed John, and my harbor freight disposable gloves were a waste of time too!
Response Posted - 08/18/2013 :  18:03:36  Show Profile
I need to try this. I've tried everything else and nothing seems to work. I'm starting to think about replacing the whole rub rail, but I'll try this first.
Response Posted - 08/18/2013 :  19:14:21  Show Profile
Have you tried MEK?
No scrubbing.
Response Posted - 08/18/2013 :  19:16:08  Show Profile
<br />Have you tried MEK?
No scrubbing.
I tried MEK. It did nothing.
Response Posted - 08/18/2013 :  19:30:39  Show Profile  Visit delliottg's Homepage
You'll be amazed at the results. I hesitate to clean mine like this simply because I don't want to be dripping acetone into the river, but next time I've got her out for the winter for projects and a new coat of bottom paint I will.
Response Posted - 08/18/2013 :  19:46:13  Show Profile
Won't any of the tiny bits of steel wool that might be stuck in the rubber molding rust after awhile?
Response Posted - 08/19/2013 :  08:17:05  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i>Agreed John, and my harbor freight disposable gloves were a waste of time too!
I use surgical gloves for that kind of work, and so far they have resisted acetone, as well as every other nasty chemical solvent or compound that we use. Don't use <u>natural</u> latex gloves, because the chemicals will disintegrate them. Use the <u>synthetic</u> latex gloves. You can get them at most drug stores. The last time I bought them, they cost about $10-12. for a box of 100. Being thin, they can be punctured, but they're more rugged than you would expect, and, if one punctures, they are so cheap that you can just toss it and pull a new one out of the box.
Response Posted - 08/19/2013 :  10:54:19  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by TakeFive</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by OJ</i>
No scrubbing.
That's surprising
Response Posted - 08/19/2013 :  11:27:47  Show Profile  Visit britinusa's Homepage
MEK... While in the British Royal Navy, we received extensive warnings about the danger of MEK if it came in contact with eyes.
Definitely wear eye protection if using this chemical. And on the Rub Rail there is a good chance that the rail will be above eye height, drips and drops are very likely to occur (and no, I do not live in CA )
Response Posted - 08/19/2013 :  13:14:32  Show Profile  Visit delliottg's Homepage
I was occupationally exposed to MEK while working as a contractor for the USN after active duty. We used it to clean our two part epoxy paint sprayers. I was young & stupid, and dipped my hands into the cleaning tank up to my elbows. I figured out that it probably wasn't so good for me when the strap on my watch melted off my arm after a couple of days of doing it.
To this day if I get MEK on me, I get an immediate metallic taste of garlic in my mouth. I have a small can of it in my shop, but I go <i>way </i>out of my way to not use it. Acetone might be a little slower at a job, but that's my solvent of choice if alcohol won't cut what I'm working on.
Response Posted - 08/19/2013 :  18:05:08  Show Profile
<br />Won't any of the tiny bits of steel wool that might be stuck in the rubber molding rust after awhile?
I avoid steel wool on the boat for just that reason. The little bits can break off and rust and stain the gelcoat. West Marine sells Bronze Wool which solves the problem.
