 Cleaned JD's hull with FSR
Initially Posted - 09/02/2013 :  06:18:11  Show Profile  Visit britinusa's Homepage
<center>
<b>After FSR wipedown</b>
Have not really cleaned below the waterline for several months other than wash with boat soap.
Here`s the difference after a very gentle wipe down with a small amount of FSR</center>
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Edited by - britinusa on 09/02/2013 06:18:47
Response Posted - 09/02/2013 :  07:28:11  Show Profile
Jealous.
Response Posted - 09/02/2013 :  07:58:25  Show Profile
An advantage of a trailered boat - no bottom paint!
frog0911
Response Posted - 09/03/2013 :  10:53:14  Show Profile
I don't know what the cost of FSR is now days, but there is a toliet bowl cleaner at the dollar store called The Works that will do the job a lot cheaper. Rubber gloves a sponge then rinse when done. The results will be the same. The boat really looks great Paul.
Edited by - frog0911 on 09/03/2013 10:54:17
Response Posted - 09/03/2013 :  11:20:04  Show Profile  Visit britinusa's Homepage
Thanks Jerry, that sounds like something to try! You are right! FSR is about $10 for a 16oz tub. I used about half a tub on the hull below the water line.
Response Posted - 09/03/2013 :  13:50:26  Show Profile  Visit delliottg's Homepage
Looks nice! I've also read that ketchup will work just as well as FSR.
Response Posted - 09/03/2013 :  14:02:58  Show Profile
Anything with a little oxalic acid in it. Ketchup qualifies.
Response Posted - 09/04/2013 :  07:49:41  Show Profile
<br />Anything with a little oxalic acid in it. Ketchup qualifies.
Do NOT put FSR on your hotdog!
