 Removing Companionway Teak
CateP
Initially Posted - 11/05/2013 :  08:39:57  Show Profile
Ahoy!
I need to replace the companionway teak guides for the crib boards and I recently purchased a set from CD. (inventory running out as they lost supplier). I did a search on the forum about removing these, but didn't find my answer. The teak guides that are on the boat look original and like they are cemented on for all time.
Any suggestions for how to get these off and installing new?
Thanks in advance.
dasreboot
Response Posted - 11/05/2013 :  09:08:54  Show Profile  Visit dasreboot's Homepage
they are screwed from inside the cabin. take off the teak trim on the inside and you will find the screws.
Response Posted - 11/05/2013 :  14:18:12  Show Profile
Mine were simply screwed through the interior trim. I removed the screws and worked the trim off the ancient bedding. Lots of scraping and cleaning before re-bedding with polysufide.
CateP
Response Posted - 11/05/2013 :  14:24:19  Show Profile
<br />Mine were simply screwed through the interior trim. I removed the screws and worked the trim off the ancient bedding. Lots of scraping and cleaning before re-bedding with polysufide.
Ahh good to know. Polysulfide is also "Life Caulk" no?
Response Posted - 11/05/2013 :  15:28:30  Show Profile
Yes. Boatlife makes a non-polysufide product called Life-Seal for bedding plastics and a 2 part product, but Lifecaulk is what you want. I did mine in black.
Response Posted - 11/05/2013 :  16:12:30  Show Profile
Remind us of what year your boat is, the trim and the way it was attached changed over time.
Response Posted - 11/05/2013 :  18:02:54  Show Profile
<br />Remind us of what year your boat is, the trim and the way it was attached changed over time.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Your profile Signature is a good place.
Edited by - Stinkpotter on 11/05/2013 18:09:45
