 5200 on sale!
Initially Posted - 01/21/2014 :  06:14:41  Show Profile
http://www.jamestowndistributors.com/mobileportal/show_product.do?pid=2002&campaign=email012114
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 01/21/2014 06:18:13
Response Posted - 01/21/2014 :  06:26:23  Show Profile
Talk about a loaded gun...
Response Posted - 01/21/2014 :  08:00:53  Show Profile
$11.99 for a caulk tube
$12.51 for shipping
vs
$19 if I buy it locally
It's a good deal for locals.
There is only one valid place for me to consider using 5200, and that is for sealing the hull/deck joint. I did one side of my Pearson 28-2 early last fall and want to do the other side of the boat this spring. It takes about 1 tube of 5200 to seal the whole thing (and about 2 days worth of work).
Response Posted - 01/21/2014 :  11:04:58  Show Profile
<< hull/deck joint. >>
Good point... I was thinking Hull/Keel...
Response Posted - 01/21/2014 :  13:42:47  Show Profile
You've both got the right attitude. There should be mandatory training required prior to purchase.
(That's from the Department of Redundancy Dept.)
Edited by - Stinkpotter on 01/21/2014 13:45:43
Response Posted - 01/21/2014 :  14:20:59  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">There is only one valid place for me to consider using 5200<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
How about...
Keeping your Toupee on
Fixing those loose Dentures
Keeping an unruly child in his seat
Fixing a blow out on your Flip-Flop...
Response Posted - 01/21/2014 :  16:47:43  Show Profile
What amazes me is that the last time I was in WM, looking for 4200, there wasn't any and they said it was being discontinued, but they had a shelf full of 5200. I bought 2-3 other things I "needed", and left the store without the caulk I went there for.
Response Posted - 01/22/2014 :  04:42:27  Show Profile
Likke... going to Home depo for some "cleaner"
Response Posted - 01/22/2014 :  05:19:30  Show Profile
what would you use to put down teak plywood on foberglass sole?
Response Posted - 01/25/2014 :  12:17:12  Show Profile
I just used 5200 to put teak down on fiberglass. My bridgedeck is too shallow to sit on and I like to have a sitable bridgdeck so I am mounting a teak and holly step as a seat. I considered drilling and through bolting but decided this was the best route.
Step 1 was clean the fiberglass with finger nail polish remover, and rough up the teak with 80 grit.
Step two put the 5200 in a pattern that will not escape the board I am mounting.
Finally I put a light sandbag on the step and will let it set up, I expect the step to be very solid as a seat.
Response Posted - 01/25/2014 :  14:23:46  Show Profile
...and if you ever want to pull it up in a few years for refinishing or whatever, some of the gelcoat will probably come with it. I speak from experience.
Response Posted - 01/25/2014 :  15:55:21  Show Profile
It is solid teak with holly strips that stick up as non-skid. Because of your unswerving support of this project it shall be known as the Bristle. As in "hey, nice Bristle, mind if I sit?"
Response Posted - 01/25/2014 :  15:55:28  Show Profile  Visit britinusa's Homepage
Perhaps a hot wire will slice beneath the seat when removal is required.
I like the seat Frank! But the Admiral was worried it would get torn up pretty quick from our many trips out of the cabin.
Response Posted - 01/25/2014 :  17:14:58  Show Profile
<br />It is solid teak with holly strips that stick up as non-skid. Because of your unswerving support of this project it shall be known as the Bristle. As in "hey, nice Bristle, mind if I sit?"
Response Posted - 01/26/2014 :  11:46:43  Show Profile
Love your brightwork, Frank! The only thing I won't swerve on is my disdain for 5200 for anything other than permanent structural joints. I had, a few choice words for the builder of my current vessel, who used it as a bedding compound. 10 yard penalty for holding!
Edited by - Stinkpotter on 01/26/2014 11:47:25
Response Posted - 01/27/2014 :  09:24:03  Show Profile
I just hope that you will have a similar smile on your face when you toss things into a hopper as I will have when people sit on my bristle. The brightwork is a companionway step from a high end motor boat and was one of my better "search:teak" events on ebay some years ago. I miss when stuff was actually on ebay. 60s yesterday, 16 now, I hope the 5200 cured over the two nice days.
Response Posted - 01/27/2014 :  12:01:12  Show Profile
Really Frank.. glue. I didn't think anything would get oily teak to stick, and you can't really clamp it together. Will water get below it and freeze and pop it off?
Well.. let us know if the Bristle pops off, hope no one is standing on it when it does...
Edited by - redeye on 01/27/2014 12:04:40
