 Poor man's cabin heat
zeil
Initially Posted - 01/22/2014 :  22:58:01  Show Profile
Somewhere in some long forgotten book or magazine I've read about heating the boat's cabin using an up-side-down 6" 15c/m clay pot on top of a stove. It is said that the clay pot will radiate nice dry heat.
Sounds like a nice and easy winter project.
Here are some thoughts and welcome any and all ideas/suggestions pro's or cons
Placing the clay pot of top of the one pit stove is easily done. To get rid of the hot and wet gas flame fumes inside the pot one will have to connect the pot to a 3/4" tube in order to vent the fumes to the outside of the cabin.
The shown clay pot bottom (top) has an 3/4" 2c/m hole to which an aluminum tube could be attached and sealed.
Routing and suspending an exhaust tube through the cabin on the way and somehow through the hatch needs a little consideration.
The heating system should be quickly and securely installed and after it cools down stored in sections.
Henk & Johanna
Edited by - zeil on 01/22/2014 23:44:32
csmcg
Response Posted - 01/23/2014 :  08:02:55  Show Profile
The "Keep Turning Left" video blog from Dylan Winter has a presentation on this method of heating. Neat idea.
Regards
ruachwrights
Response Posted - 01/23/2014 :  08:48:06  Show Profile  Visit ruachwrights's Homepage
Saw youtube of this project. Looks like it has promise. Wonder if there is a nifty way of building a nicely fitted fire proof tray which could still provide ventilation which could be secured either to the compression post or the galley.
Vern Wright
Hajime
ruachwrights
Response Posted - 01/23/2014 :  08:54:47  Show Profile  Visit ruachwrights's Homepage
Also would the candles used as heating source in the "Boat Owners" site need venting? Would open door to head and opened head window or v-berth hatch be sufficient? (http://www.keepturningleft.co.uk/)
Response Posted - 01/23/2014 :  08:58:05  Show Profile
That's an ooooold trick for an alcohol stove--not sure about doing it on propane or butane. But please do vent it outside. Alcohol produces significant amounts of CO. I know someone who did it without any vent--I'm glad they're still with us, but I don't take that as a sign that it's safe.
Edited by - Stinkpotter on 01/23/2014 09:02:31
Tomas Kruska
Czech Republic
Response Posted - 01/23/2014 :  12:33:06  Show Profile  Visit Tomas Kruska's Homepage
After a 5 minutes of reading that web, It got me thinking its more dangerous than effective heater.
More effective would be just to light the candles itself without any pots. In a small rooms like boats it would kill you - consuming O2 and releasing CO.
Sorry, but this does not work as expected. Save some money instead of buying beer packs and buy diesel heaters
zeil
Response Posted - 01/23/2014 :  13:18:25  Show Profile
Thanks for the input...
We've used up to 4-8 candles during past cruises and trips. Works well and provides a measure of dry warmth but... in cold/wet/windy anchoring spots it would be nice to have, during the evening, a little more warmth and a better chance to dry out
One of those days when it is wet, windy and cold outside the cabin.
With the head's port window just cracked open enough fresh air should be available to ventilate the hot damp fumes inside the clay pot through the exhaust pipe to the outside. If this is insufficient more fresh air should come in through the cabin's sliding hatch.
iwillnotsubmit
Response Posted - 01/25/2014 :  08:17:25  Show Profile
I have never heard this trick before, until yesterday at Strictly Sail Chicago. The founder of Blue Water magazine was giving a seminar about cruising in the Bahamas and was relating how the nights got a little chilly. He said he used the clay pot method for many nights with no problems. I don't remember if he specified the fuel used, but he didn't say anything about venting.
Response Posted - 01/25/2014 :  10:06:18  Show Profile
I saw a discussion of this subject on another sailing forum, and someone pointed out that putting a clay pot over the candle didn't add any btu's of heat. You got the same amount of heat simply by burning a candle. I think burning a candle or two might take off a bit of a chill, as long as you're careful, and don't leave them, burning after you go to sleep.
Response Posted - 01/26/2014 :  11:16:38  Show Profile
I think the idea is the pot disburses the BTUs better as radiant heat, and captures some water vapor and soot from the combustion. But I've never tried it.
gottoaz
Response Posted - 01/26/2014 :  19:34:03  Show Profile
http://www.youtube.com/watch?v=brHqBcZqNzE&list=TLxVstTTUAkgYVNXJX2W1dxUfajiEChadU
Copy and paste into your browser for the Dylan Winter You tube video csmg mentioned earlier. It actually looks like it might be pretty good under the right circumstances.
Response Posted - 01/26/2014 :  21:26:37  Show Profile
A tea light candle radiates about as much heat as a 50 watt lightbulb, or one adult human. The pot absorbs most of the light and radiates it as heat, but you've only got 50 watts no matter how you stack it. 10 candles would be similar to an electric space heater on low without the fan. I would definitely be installing a CO monitor in the unlikely event that I ever considered candle
zeil
Response Posted - 01/26/2014 :  22:48:15  Show Profile
Thanks guys for your notes/suggestions/observations and concerns
The idea for this poor man's "heating system", is to use the boat's propane stove, without candles, and using a sectional 3/4" tube to expel fumes to the outside of the cabin.
Both the 6" clay pot as well as the aluminum exhaust tube should radiate dry heat while the propane fueled moist air is to be funneled to the outside.
The "poor man's stove" should be as safe as cooking dinner without having to deal with pounds (buckets), of exhaust water vapor.
We'll need to experiment with simply connecting and disconnecting the exhaust tube to the clay pot as well as to find a convenient and safe route for the exhaust tube to outside of the cabin.
We'll assume the, somehow suspended, tube to get very hot as well.
For easy storage after use the " heating system" will need to be compactly stored...
Need to decide the best route for the exhaust pipe from the clay pot out through the hatch... any ideas??
SEAN
Response Posted - 01/27/2014 :  04:53:01  Show Profile
http://www.amazon.com/Mr-Heater-Portable-Buddy-Propane/dp/B002XXI608/ref=sr_1_5?ie=UTF8& qid=1390822782& sr=8-5& keywords=heater big buddy
we use this heater , it works great , theres also a oxagen shut off and a hose you can connect to a larger tank .
we hang it by the sink facing forward ..it also fits under the seat on our wk when not in use ..it makes a nice fireplace .
Response Posted - 01/27/2014 :  09:18:27  Show Profile
Hey Henk, are you forgetting Johanna? My first mate is a stove of considerable output all by herself... have you tried cuddling? I suppose a goal to be able to get out of bed without freezing is a good one though.
Tomas Kruska
Czech Republic
Response Posted - 01/27/2014 :  12:06:13  Show Profile  Visit Tomas Kruska's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by pastmember</i>... have you tried cuddling? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
zeil
Response Posted - 01/27/2014 :  18:02:32  Show Profile
Dictionary
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">cuddle |#712;k#601;dl|
verb [ trans. ]
hold close in one's arms as a way of showing love or affection :| they were cuddling each other in the back seat. | [ intrans. ] the pair have been spotted kissing and cuddling.
• [ intrans. ] lie or sit close and snug : I love cuddling up in front of a fire | they cuddled together to keep out the cold.
noun
a prolonged and affectionate hug. Like hugging, cuddling makes the body release oxytocin, causing has various effects.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
We'll give it a try with renewed energy
