 Boat Yard Tools Explained!
Initially Posted - 07/12/2014 :  08:14:47  Show Profile
I stumbled across this on a boat repair website. You might want to put something soft on the floor so you can roll around.
My favorite is the SOB Tool!
Boatyard Tools Explained
The beginnings of a dictionary for boat shop use
Tools Explained
AIR HOSE:
see extension cord. Also used while connected to spray gun to create random stripes in otherwise boringly consistent fresh paint.
ALLEN WRENCH:
Various sized hex shaped steel shanks used for rounding out sockets in impossible to remove recessed set screws. Invented by some guy named Al who liked to watch people use hack saws to remove cutlass bearings.
APRON:
A cloth device with a fiberglass dust impregnated rope used for irritating user's neck.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
BATTERY POWERED DRILL:
A device used to hold various drill bits while operator waits for the battery to recharge.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
BENCH GRINDER:
Used to overheat and otherwise ruin drill bits and chisels
BOATIE:
Uses archaic terms terms like foresl and steaming light and calls boats she. This person never buys lunch or delivers free chilled beer. Likes to waste time of others by asking endless questions so he can inform the respondent that the freely given advice does not match that given on line, in a book, or by a surveyor.
BUFFER:
A large heavy tool with a spinning fluffy pad used to tightly wind extension cords and break wrists of operator.
CAMERA:
An image capturing device left in its storage bag whenever something unique memorable and fleeting occurs.
CELL PHONE:
A device carried in the pocket of a craftsman that rings to alert said craftsman that his hands are covered in gooey stuff that stains.
CHARLIE SHEEN PHOTO:
A prominently displayed picture used to remind us all we could be bigger (expletive deleted by system)s
CLAMP ON UTILITY LIGHT:
Like the TV ad says, "Clamp on. Clamp off." This device is a cold weather tool used for distributing small shards of heat lamp bulbs into carefully applied epoxy coatings.
CLIPBOARD:
A hunk of cracked flexible material with a metal spring loaded thing generally used to hold pencils with broken leads, pens that won't write and sopping wet paper. Usually left sitting on edges of whatever overhangs fresh wet paint or well polished molds.
COUNTER SINK:
Used to gather teak chips and spin those chips around to make a hole slightly larger than the currently available plugs. Also used to make it easier to pull fasteners through other side of expensive pieces of wood.
DEEP CYCLE MARINE BATTERY:
A big heavy weight used for gluing plywood sheets into slightly warped assemblies that have stains from leaked battery contents
DIE GRINDER:
High speed rotary tool. Commonly used in combination with a sharp rotary file to cut into bottoms of wet boat so nasty stinky red liquid can squirt in eyes of operator.
DISC SANDER:
A rapidly spinning motorized tool used to make deep gouges in otherwise smooth and fair surfaces. Also used to apply a layer of dust to freshly varnished surfaces. Can be used to throw small chip in eye sockets when user needs to express feminine side by making tears flow.
DOCK:
Used for making dents in bows and gouges in freshly applied topsides paint.
DRILL BIT:
A used as a tool inserted and broken off in expensive metals and fittings to help operator realize his last pair of Vice Grips fell in the lake yesterday.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
DRIVEWAY:
place where boaties park just before someone with a real life needs to come or go.
DUAL ACTION SANDER / AKA DA:
An air powered device used to make operator's hands lose feeling. designed to distribute tiny droplets of compressor oil over surfaces before application of urethane topcoats.
8" SOFT SANDING DISC:
Installed on a buffer motor, this handy tool launches fresh sticky backed sandpaper discs into piles of dust.
ELECTRICAL METER
1. a device designed to bring the operator within easy reach of painful or lethal electrocution.
2. a random number generator
EPOXY PUMPS:
Used to dribble epoxy wherever cans are stored
EXHAUST FAN:
Extends effectiveness of spray gun to coat windshields and cause windshield wipers to be replaced
EXTENSION CORD:
A trip wire device for launching expensive tools from decks of tall keelboats
Fid:
A rusty semi pointed Phillips head screwdriver that lacks the ability to turn Phillips head screws. Used for stabbing palms of those who wish to loosen tight knots.
FLAT BLADED SCREWDRIVER:
A very dull chisel or flimsy pry bar. Commonly used to wallow out slots in little metal thinghies.
FLOOR:
Overflow containment area for workbench
GEAR PULLER:
A big bolt with arms attached whose function is to break off chunks of pulleys after use of allen wrench.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
HOLE SAW:
A circular device placed in battery powered drills to immediately kill batteries. Can also be used in large old pre-safety clutch heavy duty drill motors to sprain or break operator's wrists.
HOSE CUTTER:
A tool used to make hoses too short.
off topic>>>
INCIDENCES:
A term whose use makes it clear the user has no clue how to spell incidents or what incidence means.
INFRARED PROPANE HEATER:
Most common boat shop version is the style mounted on a refillable portable tank. It's primary use is melting the ass out of disposable coveralls.
INVOICE:
Used when a boatyard craftsman needs some privacy, this device when filled out with a reasonable number at the bottom makes any customer who has stopped by three or more times go away until a private investigator is paid to find that customer...whose wallet and checkbook will not be with him.
JIGSAW:
A device used to chip edges of teak faced plywood. Also handy for making crooked edges that when straightened leave insufficient material to make the desired bulkhead.
KNOT:
A term used by sailors to lie about distance or velocity. Something only boaties can permanently create to ruin otherwise perfectly useable ropes.
KRYLON:
Used to "rebuild" engines without the need to take anything apart or replace old parts.
LADDER:
Used for elevating open paint cans and fragile tools so they can better impact the concrete floor below.
LEDGER:
A notebook for recording those occasional small business transactions
LEGAL PAD:
A bound stack of paper, usually on a clipboard, used for drawing pictures nobody can understand after turning to a fresh page and permanently hiding very important reminder notes from being seen
MARINE SURVEYOR:
A particularly obnoxious know it all who causes minor repairs to cost ten times more and who prevents boat owners from either selling their boats or obtaining insurance coverage.
MASKING TAPE:
A paper product used with rainwater to permanently affix itself to freshly painted surfaces. Also good for dropping in wet paint.
Marlinspike:
see fid
OUTBOARD MOTOR:
An aerobics arm pull exercise device for those who can't make to to the gym. Smallest versions are useful for spilling gasoline in bilges.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
PAINT BRUSH:
An expensive carefully selected flexible bristled single use tool used for extracting discs of hardened resins and paints from inexpensive mixing cups.
PAINT ROLLER:
A furry or foam covered cylinder used to place epoxies and antifoulants on boat topsides just above masking tape and on trailers and floors.
PAINT SHAKER:
A nifty motorized clamp used to throw droplets of expensive paint uniformly around the room.
PAINT STIR STICK:
A simple wooden device, usually provided by paint salesmen in hopes they will be used to slosh expensive paint over the sides of formerly full cans.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but, can also be used, as the name implies, to strip out Phillips screw heads.
PIPE WRENCH:
A tool with large "toothed" jaws used to make gotchas on otherwise smooth trailer hitch ball nuts
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
PRINTER:
A piece of office equipment used for wadding up paper
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PUTTY KNIFE:
See chisel, screwdriver, paintbrush, utility knife. commonly used with bench grinder mounted wire brushes to smash knuckles and maim fingers.
RAMP:
Parking lot for boaties.
SHOP DOOR:
A device designed to be open when bad things will blow in and closed when keys are lost. Overhead version is also good for dripping filthy water on fresh varnish and clean clothing
SCAFFOLDS:
A rolling ladder capable of carrying a wider variety of spill able and breakable things. Those with end ladders can also be used for ripping crotches of coveralls.
SEXTANT:
No need for a definition, if you give a damn you already know what it is and how to use it, otherwise you are a boatie looking for more terms to insert in your endless conversations.
SHOCK CORD:
see also owner line. A pacifier for boaties whose application is to be led through the deck to dead end attachment. Common directions for use are, "Here. Hold this and whenever it feels like the athwart ships hazlehorf is defragmitulating, pull it hard three times."
SHOP VACUUM:
A efficient device used to hide expensive tiny parts in bags wet mildewed dust, insects and spiders. Most have patented "Easylose" drain plug and can be used with dust filter removed to suck nasty oily water from bilge so it can be spilled on cabin cushions.
This tool is generally used after work inside boats is complete to blow a homogenized air and dust mixture all over the shop.
SKILSAW:
A portable cutting tool used to make studs too short.
Son of a b***h TOOL:
Any handy tool that you grab and throw across the garage while yelling "Son of a b***h" at the top of your lungs. It is also, most often, the next tool that you will need.
SPRAY GUN:
Used to cover anything difficult to clean or expensive with an unwanted color of tiny paint droplets.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity
TAPE MEASURE:
A long flexible steel blade used to draw crooked lines. Also can be used to make blood blisters when brand new or to slice insides of fingers and palms while trying to shove the f#%@ing blade back in the smashed housing...see ladders.
TARP:
A canvas or plastic sheet used to save dust and dirt from filthy projects for distribution on otherwise clean boats.
TRAILER COUPLER:
A sturdy device used for mangling license plates and denting bumpers.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
TWEEZERS:
A tool used to dig holes in skin in the general vicinity of splinters.
U SHAPED TOILET SEAT:
Reduces incidence of neck breakage while OSHA inspectors or surveyors drink
UTILITY KNIFE:
A simple aluminum housing with replaceable blades used for creating sharp edges on cardboard and paper cuts on those who handle that cardboard. Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while you are wearing them.
VIDEO CAMERA:
A modern recording device left in storage case whenever something important is going on.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, ***#!"
WOOD CHISEL:
A pointy ended fragile screwdriver and flimsy pry bar. Commonly prepared for its other use by placing against a screw and whacking its handle with a hammer, this device can wear out sharpening wheels.
WORK BENCH:
Sturdy elevated storage area for partially used but unsealed cans of paint, any tool used within the last year, used paper towels, empty pizza boxes, the hand held phone (buried with paint in keys), any container that leaks corrosives, carious hand tools, and dust.
Also used to make nice black areas in the middle of white gelcoat repairs.
WRENCH:
see hammer
Akenumber
Response Posted - 07/12/2014 :  10:06:00  Show Profile
Ok, now those were great.
