 Drifter/reacher
Bryan Beamer
Initially Posted - 02/23/2003 :  21:13:55  Show Profile
I just purchased Gary Clarke's 155% Ullman drifter. I have never owned one or used one on a c250. I have a couple of questions maybe you can help me with.
What is the max wind you should use the drifter in?
Can you use a whisker pole with the drifter? If so what length do I need?
I have the winches over the coaming compartments so all I should have to add is stanchions blocks on the stern pulpit.
I have seen picture of a foot luff control run to the cockpit to adjust the luff. Can the luff be controlled with a small line connecting the foot to the forestay chain plate then use the halyard to adjust tension?
Any ideas or help with this is greatly appreciated.
Bryan Beamer
<img src="http://im1.shutterfly.com/procserv/47b3dc23b3127cce9462f2858f2b0000001010" border=0>
Daylight Again
C250wk #495
Response Posted - 02/23/2003 :  23:46:33  Show Profile
Bryan, very good on the aquisition. The sail is good up to about 8 knots. It will overpower the 250 about the time that its wind limit is reached.
You have it right on the sheeting. I used 1/4" sheets and the small blocks that Ullman supplied. They are mounted on the Harken stanchion mounts that was depicted recently.
You also are right about using a block at the stem and running a tack line thru it and back to cockpit and as you have the extra winches use one of them.
Ullman gets a full cut out of the sail so hoist it until the jib halyard shackle jams and it will leave a short tack line distance when hardened for weathering. Off wind let her out and fill up...sometimes 30 inches or so.
The sail is too light for a pole and its not needed. It will fill and hold shape in very light wind.
I like to hoist and douse in the lee of the main while on a broad reach...and use some method of securing the sail bag. I have a couple of eyes on the bag and added two twist locks on the port boom forward.
Enjoy
http://www.stewartfam.net/arlyn/drifter.html
Arlyn C-250 W/B #224
R&R N/E Texas and Great Lakes
