It has always amazed me that Garmin did not come up with a simple add on to their chart plotters to provide auto pilot control out put to drive an Auto pilot power head.
It sounds easy in theory - the chartplotter just tells the the power head to turn left or right. But there needs to be PID controller logic to prevent cumulative errors from building up, and to damp out oscillations caused by wave motion of the sea, etc. All that logic is typically built into the autopilot's control head, and that function would need to be programmed into the chartplotter if there was no control head.
Plus, the most popular operating mode of an autopilot is simply maintaining a steady compass course, so the autopilot comes with its own fluxgate compass for that. That would have to be built into the chartplotter also.
The standard way of doing this with a traditional autopilot in "track mode" is for the chartplotter to feed data on bearing to waypoint and cross-track error to the chartplotter, which uses its PID logic to maintain a steady course to the waypoint and minimize cross-track error without causing wild oscillations. Like David, I've done this with my Raymarine ST4000+. Instead of a turnkey chartplotter or GPS, I use OpenCPN on a Windows tablet. And I managed to do it all wirelessly via Bluetooth, so I can move the tablet anywhere on the boat without a bunch of wires dangling around.
There have been a couple times when I managed to run an all-day pre-programmed course from the Chesapeake Bay, through the C&D canal, and up the Delaware River. I did keep a constant watch to make sure the course didn't take me right thorough a buoy or a freighter's path.
Rick S., Rock Hall, MD PO of Take Five, 1998 Catalina 250WK #348 (sold in 2016) New owner of 2001 Catalina 34MkII #1535 Breakin' Away (sailing from Swan Creek in Rock Hall, MD)
The control head also includes the motor driver, a component that isn't generally a part of a chartplotter. The motor driver takes a low level analog signal and uses that to provide a proportional amount of drive to a high power motor (what actually turns the wheel or pushes the tiller).
The plotter also doesn't have the necessary fluxgate compass, and may not be positioned in the best place to have one (especially since most plotters include a magnetic latching door to hold the memory card closed).
Alex W Seattle, WA Express 37 "re-Quest" previously owned 1984 Catalina 25 "Lutra"
