Also, on the outside, you probably only see a hole in the hull. A proper thru-hull has either a countersunk, flat disk (which mine had) or a "mushroom" that holds it to the hull when the aforementioned nut is tightened inside. It's interesting, however, that you have a ball valve (good) rather than a gate valve (put in the older models).
Dave Bristle PO of 1985 C-25 SR/FK #5032 Passage before going over to the Dark Side (2007-2025); now departed from Mystic, CT, and boatless for the first time since 1970.
