 Ocean towing
zeil
Initially Posted - 07/13/2016 :  15:12:04  Show Profile
Yesterday while underway from Chemainus to Telegraph Cove a mere distance of about 5nm, the 8hp Honda quit after stuttering a bit.
The way is stopped sounded like a gas problem. Sure enough a spot of dirt was sucked up from the tank, removed from the motor intake and voila, it ran fine again. We're considering installing now a fuel filter. Any suggestions?
It makes us think of the question of having to tow the boat for longer distances, through choppy water, etc. Question is where and how would you connect a tow line, how long should the tow-rope be and if you have experience at what speed.
Henk & Johanna
Response Posted - 07/13/2016 :  16:05:55  Show Profile  Visit delliottg's Homepage
I installed this Racor some time ago: Racor fuel / water separator. I mounted it on the starboard side of the fuel locker on the outside so it can be drained easily or the filter replaced.
As far as towing, I'd think you'd want to be several boat lengths back from the towing boat and at a distance that put you on the down slope of the wake to minimize the strain on the line. You'll want to make sure that you can easily release the towing line at your discretion, not the towing boat's. I've read about taking wrapping lines around the mast and then up through the cleat(s) on the bow, but I'm not so sure that's a great idea. Maybe if our masts were keel stepped & not deck stepped.
David
C-250 Mainsheet Editor
Sirius Lepak
Response Posted - 07/15/2016 :  11:48:54  Show Profile
A commercial co. like TOWBOAT US will generally tie you to the stern quarter with fenders in good conditions. On a line, you generally want a multiple of the wave period of at least two. There is a risk of fouling the prop if the tower is climbing a wave and the towee is sliding down the face of its wave and the line goes slack. A bridle to both bow cleats and a central ring to attach the towline with a slipped bowline is a secure approach.
edit: I have a Sierra filter that is essentially the same as a Racor and there are probably the good brands. I mounted it on the transom in the fuel locker towards midship. It worked well until I replaced one of my tanks and no longer have clearance for 2 three gallon tanks. I'll be moving it to the cockpit transom soon.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Edited by - Dave5041 on 07/15/2016 12:00:03
Response Posted - 07/15/2016 :  12:35:10  Show Profile
Ive been towed twice in my lifetime by SeaTow. I have their insurance. They are very professional and will hook you up properly for the conditions. If it's a fairly long tow they will pull you and when you get close to the Destination they will then switch to a hip tow tied to his side so he can control the two boats as one. The tow line is on a reel and he will adjust the length of the line for the best possible ride. They tow you very slow and all you have to do is sit back and enjoy the ride. Uh
Edited by - islander on 07/15/2016 12:38:37
Response Posted - 07/15/2016 :  13:48:43  Show Profile
I second the recommendation for a commercial service, and have a subscription with TowBoatUS (Vessel Assist in some areas). On open water, conventional wisdom is 25' boat should be on at least a 200' tow line. While most of us only have an anchor rode that long, it's not a great idea for a tow line because twisted nylon can stretch such that if it breaks, it can be explosively dangerous to people on either end. Commercial towers use a heavy multiple-braid line and, of course, know how to attach it the best way for the situation. Just make sure, when the assistance arrives, that you and they are in agreement as to whether it's a simple tow or a salvage.
I've never had to use their services in the 17 years or so I've had the contract (KNOCKING ON WOOD), but knowing they're there is worth it.
zeil
Response Posted - 07/22/2016 :  10:52:14  Show Profile
Thank you guys for the recommendations and advice. Probably the best point to hook up to for towing is the boat's bow's trailer strap eye. It should be able to take a lot of strain and pounding.
By the way we did purchase and installed a West Marine $15.00 in-line fuel filter to eliminate impurities
A little over halfway of our 2 month long Gulf Island meandering we are on the point of heading north towards Desolation Sound. But first we plan to go up the Fraser river past New Westminster and exit out of the north arm of the Fraser river toward Gibson in the strait of Georgia.
Henk & Johanna
Edited by - zeil on 07/22/2016 11:22:40
Response Posted - 07/22/2016 :  13:21:02  Show Profile
A consideration regarding the bow eye: The tow line should be easy to disengage very quickly from either end, even if by cutting. The bow eye might make it difficult to reach and unhook or untie from on board.
zeil
Response Posted - 07/22/2016 :  15:43:22  Show Profile
Concluded that the bow eye is almost impossible to reach from the fore-deck and could be hazardous in rough seas.
Seams the best way is to prepare a bridle fastened on either side to the mooring line cleats.
Henk & Johanna
Response Posted - 07/23/2016 :  04:04:45  Show Profile
Some people use the bridle concept to capture and pull the tow line through at the bow but to pull the attachment point of the tow line back to the mast. This is where they secure the tow line to the towed boat. The knot here is key - it should be secure, not subject to capsize and easy to untie in a hurry, not jam.
The bridle keeps the point of effort at the bow to stabilize pitch and yaw but puts the physical connection point of the tow line at the mast providing (1) connection to a very solid mounting point and (2) a convenient place to quickly disconnect the tow line in case it fouls.
Response Posted - 07/23/2016 :  07:21:45  Show Profile
I'd feel better about using the mast if it was stepped on the keel--the C-25 tabernacle worries me for that kind of force. From what I recall when I removed and re-mounted it with a base plate for blocks, mine was held by two small lag screws and two smaller bolts with small washers--not as robust as cleats with backing plates. And the material is fairly thin sheet metal with a single bolt through the mast. With the combination of upper and lower shrouds and stays, I suspect the sailing forces are mostly straight down, and the whole rig drives the boat, so the design is adequate to hold the base in place (obviously). Putting all of the driving force at the tabernacle, including sudden forces from waves, and the tow boat possibly trying to exceed the sailboat's hull speed, worries me. I'm not as familiar with the one on the C-250.
Edited by - Stinkpotter on 07/23/2016 07:26:40
Sailynn
Response Posted - 07/23/2016 :  23:40:38  Show Profile
the two bow cleats are rated for more pulling strength than a bow eye, and it would be way more difficult to un-tie from the bow eye. IMHO use the bow cleats and bridle line.
disconnect
Lynn Buchanan
1988 C25 SR/WK #5777
Sailynn
Nevada City, CA
zeil
Response Posted - 07/25/2016 :  08:09:49  Show Profile
Thanks for your input... After evaluating all points of attachments a bridle attached to the bow cleats seems to be the best solution. The mast tabernacle is indeed fine for vertical forces but doubtful for horizontal sheer forces. Considered attaching a line to the fore-stay bow stem but that does not seem a good idea either. So a bridle connected and easily removed, to the cleats it will be.
Henk & Johanna
