 How do you tack?
HerdOfTurtles
Response Posted - 05/09/2019 :  09:19:58  Show Profile  Visit HerdOfTurtles's Homepage
Just measured. We tacked through 111 degrees.
1978 Standard Rig
Fin Keel
L-Dinette
Response Posted - 05/09/2019 :  10:21:52  Show Profile
Originally posted by HerdOfTurtles
Despite all my strength and pulling out from the mast on the jib halyard for leverage I could not get the Genoa tight enough and there were 2" deep scallops between the hanks. I'm not 100% sure what the problem is but it may be the Genoa luff is slightly too long. I also loosen the backstay prior to tightening the jib halyard, then crank down on the backstay after to try and get it a bit tighter.
When I first bought my Cal 25 I had the same problem. It might be that the luff is too long as you suggested, but I got lucky and found a simpler solution. The previous owner installed a snap shackle at the head of the sail and at the clew. Snap shackles are much longer than ordinary D shackles, so I replaced the snap shackles with small D shackles, and that enabled me to get the jib's luff as taut as I needed to. Look at your shackles and see if you can do the same.
If not, a sailmaker should be able to shorten your luff a couple inches.
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 05/10/2019 :  05:58:59  Show Profile
Originally posted by redeye
Then I move my beer from the low side to the high side
As I read through these twenty posts, I felt like everybody was forgetting a step.
Seth
"Nomad" 1980 Prindle 16
keats
Response Posted - 05/10/2019 :  11:23:41  Show Profile
My preference is to deploy a port and starboard beverage. Then I don't have to think about it.
Tim Keating
1985 C-25 TR/FK #4940
Midsummer
Lake Don Pedro, CA
