 @#!%#@ LEAK
Mark Loyacano
Initially Posted - 04/16/2003 :  20:49:18  Show Profile
There is a persistent leak in my cabin. Every time I seal things up where I suspect the source to be ... it returns.
Starboard side of boat, about six inches aft of the most aft window above the inner liner seam. It appears to be coming from the rail...but I have loosend the screws and injected liquid sealant under the screw heads.
The windows don't leak, the stanchions aren't leaking, this is driving me nuts.
Mark L.
Cat 25 SR/SK #549
Response Posted - 04/16/2003 :  21:25:25  Show Profile
How about the rub rail? Have you removed the interior teak trim strip along the hull-deck joint and looked for a leak (during rain or with a hose)?
Response Posted - 04/17/2003 :  13:42:42  Show Profile  Visit Champipple's Homepage
I have to second Dave on this one. The track for the rubrail has a screw every 3 or four inches. We took the entire rail off and recaulked the rail itself and each and every screw...
dw
George Beck
Response Posted - 04/17/2003 :  16:05:04  Show Profile
I would bet on the rub rail as the problem. I remember several years ago I removed the rail from a 22 Catalina and was surprised and disappointed to find several holes drilled completely through into the V Berth which were never used to secure rail. I noticed them while the rail was off and I happened to be in berth and noticed daylight. Surprise,surprise. Good luck.
George Beck
Response Posted - 04/17/2003 :  16:05:17  Show Profile
George Beck
Response Posted - 04/17/2003 :  16:05:24  Show Profile
Mark Loyacano
Response Posted - 04/17/2003 :  22:42:27  Show Profile
Thanks all. The rubrail is the next project then. It will be a good time to install the upgraded stem fitting (with achor roller) that I got from CD last Summer.
Mark L.
Cat 25 SR/SK #549
Todd Frye
Response Posted - 04/18/2003 :  17:20:10  Show Profile
Mark,
In my murky memory I recall reading about, what seemed like, a nifty way to locate a leak. Seal all obvious cracks/openings (like companionway boards, cockpit lockers, through hulls, etc.) and run a shop vac hose (blowing out) below decks to create positive air pressure. Then apply a soapy water solution around handrails, stanchions, chain plates and windows and wait for the air leaks to bubble up. Good luck. Todd Frye
Response Posted - 04/21/2003 :  14:12:26  Show Profile  Visit Champipple's Homepage
UH OH ----------
Some one had to bring up the pressurized cabin again....I'll just sit and watch, this one usually gets interesting
Bruce Chilton
Response Posted - 04/28/2003 :  22:20:04  Show Profile
After spending a lot of time chasing leaks in the cabin, I read about an ingenious method for locating the leaks instead of trying to guess where they were coming from. And IT WORKED.
The method is simple, it entails application of positive air pressurer in the cabin and detection of the leaks by application of soap solution to fittings which will bubble if there is a leak. Simple, right?
I used an electric leaf blower to produce the positive pressure. An alternative souce of positive pressure could be a shop vac.
I introduced the pressure source through a hole in a 1/4 inch plywood board cut to fit the forward hatch. Duct tape was used to secure it and to seal it to the cabin. To make sure that the air introduced into the cabin did not escape through the main hatch, I sealed the perimetrer with duct tape including the joints of the
boards and the vent slots in the top board.
Once I set the leaf blower going I went over all the fittings with the soap solution.
Bubbles were generated at the main chain plates and one of the cockpit scuppers or drains.
After rebedding the chain plates and replacing the cockpit scuppers
I have had no further leak problems. That was two seasons ago.
I am sure that the proceedure sounds elaboate. It reall isn't it is simple. The whole thing, not including repairs, took about 1 1/2 hours And it sure beats guessing about the source of the leaks.
