i removed the old depth meter and knot meter from my 1980 SK/SR and now have two big holes in the starboard side of the cockpit. I want to cover these 2 holes with a nice piece of wood. I have 2 questions..
1) what type of wood (other than teak) could i use assuming i am going to coat it 3 times with cetol.
2) I was going to put 2 pieces of wood, one on the inside and one on the oputside bolted all the way through. Should i also cut 2 round pieces and fillup the holes? or can i leave 2 "hollow" spots in between the wood where the instruments used to be?
thanks again.. my list of projects gets longer everytime i log into this site!!! I'm all smiles though!
You could use mahogany to fashion a cover for these holes or you could get creative like Doug and Richard.
This is what Doug did on Wind Lass.
"The previous owner had left me with a cheap plywood patch over an old compass hole. Port side of the aft cabin bulkhead. Here is what I did. Purchasing a deck hatch/port for 10 dollars I installed it into the hole. I used a clear port so it would look similar to a portlight. I must say it was a vast inprovment over the old plywood patch. A few months went by and some one gave us a stained glass sun catcher. My first thought was Ill bet this will fit into the old port and look quite nice. I removed the chain and hangging loop and here is a picture of how it ended up." <img src="http://im1.shutterfly.com/procserv/47b2d626b3127cce9f241b0eb9830000001410" border=0>
And this is what Richard did on Sanity,
"Here's what I did."
<img src="http://im1.shutterfly.com/procserv/47b2d628b3127cce9f2bdac48e4f0000001410" border=0> "It used to be a knotmeter which never worked. With a very bulky backside with many sharp, jagged points, it liked to gouge out large chunks from my skull when I used the sink. So I struck back one day! I removed it and used a hack-saw to cut off the backside about 1" from the glass. After removing all the "innerds", I reinstalled it back in the hole in the bulkhead. On the inside, a router table was used to make the trim piece from some scrap teak. If I did it again, I would glue the trim piece on the inside, instead of using screws."
The above pictures of my stained port still look great. I used a West marine deck access plate and a cheap fake stained glass from a gift shop. The deck access plate had a clear plug and the stained glass was put into the inbd side of it.
going to look for those deck access plates.. thanks alot.. as always these forums come to the rescue..<img src=icon_smile_blush.gif border=0 align=middle>
