 Another teak re-bedding question
John J.
Initially Posted - 05/03/2003 :  18:24:40  Show Profile
When I re-bed my exterior teak trim, How much sealant should I use? Should I just apply it around the surfaces near the screws or should I spread it over the entire surface to be re-attatched?
Response Posted - 05/03/2003 :  18:47:37  Show Profile
For the handrails I applied a circle (~3/8" bead) of polysulfide around the screw holes. I only tighten the screws about 90% initially - allowing the sealant to cure for 7-10 days - forming a gasket. Then tighten the rest of the way - trimming the excess.
Edited by - OJ on 05/03/2003 18:48:27
John Mason
Response Posted - 05/05/2003 :  14:58:02  Show Profile
If you do a small countersink to the hole in the deck and the hole in the bottom of the handrail, the sealant will form an "O-ring", of sorts, that will help it stay sealed better.
John Mason
<img src="http://www.users.qwest.net/~jamason/ali.jpg" border=0>
pronounced "Ali Paroosa"
1982 - FK/SR #3290
