along with gas, my boat also came with the water and holding tanks about half-way full. i know i can obviously pump out the holding but what about the water? do i have to send it all the drains into the holding tank then pump out? or can i pump out directly from that tank.
There's usually a cleanout and inspection port on top of water and waste tanks. You could get the old water out through there if you don't want to send it through your water lines. By the way, are you sure your sink drains go to your holding tank? I think most don't.
Its only water. Does the sink pump work ? If so pump it for 10 minutes it will empty the tank and drain through the sink drain. Worst case syphon it out with a hose.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> i know i can obviously pump out the holding but what about the water? <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Just don't pump out your head holding tank anywhere inside of 3 miles in the ocean and at all on lakes and rivers.
i was going to pump out he holding at the nearest station, i think my marina has one, i figured since i was there i should get rid of the old water too.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> i was going to pump out he holding at the nearest station, i think my marina has one, i figured since i was there i should get rid of the old water too.
Steven de Filippis 78 C25 SR/FK - Gypsy <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
In that case, I am not sure if you are going to want the same fitting at the pump out station coming into contact with anything potable.
