 Repainting deck areas
martinsokolowski
Initially Posted - 05/23/2003 :  21:43:54  Show Profile
What paint (manufacturer and specific color and model number) is recommended to repaint the tan/beige deck areas of the topside?
Thanks.
Martin Sokolowski
Plano, TX
martin.sokolowski@verizon.net
Catalina 25, hull #742
Response Posted - 05/24/2003 :  11:06:20  Show Profile
(1) DON'T PAINT YOUR DECK - you'll regret it the reat of the time you own the boat
(2) What's the reason or cause that makes you want to paint it in the first place?
martinsokolowski
Response Posted - 05/24/2003 :  20:14:57  Show Profile
I want to paint, or perhaps more accurately, put a non-slip deck finish on the the walking areas and cockpit aras. The current areas with the molded in patterns and colored beige are worn and no longer non-slip.
Suggestions?
Martin Sokolowski
Plano, TX
Response Posted - 05/24/2003 :  20:30:58  Show Profile
Wow, I've never heard of gelcoat wearing through, but considering your hull number I suppose . . .
I would contact Minicraft of Florida first - which sells <i>professional</i> gelcoat products and have original colors.
If that's not appealing then I'd look at topside paints offered by Petit - prep will be key of course.
Keep in mind when you get a scratch in paint you'll have to feather it out before re-painting. Gelcoat is much more durable and forgiving - hence my all caps above.
Good luck.
Edited by - OJ on 05/24/2003 20:31:59
