I just purchased a 1978 Catalina 25 SK. Your forum has helped me in many ways. One topic I have not seen, and I can not figure out myself, is how to access the back of the electrical connections. I can see them by sticking my head into the port locker in the cockpit but I can not figure out how to reach them. Previous owners have made several changes and I want to 'clean up' the wiring in this area. Any help ? Thanks, Tim
I haven't looked on mine, but I wonder if you can unscrew the electrical panel from the front, and bring it out to the galley? Does everthing work? (mostly?) If you climb down into the port locker, tie up the lid with a line to the stern rail. Don't want you to get locked in there.
I just did the same thing on our 1979 FK 25. As best as I could figure, you just have to climb in with your flashlight and do whatever you have to do. I'm 6'-2" and 200 lbs and didn't think I'd fit, but was able to make it down without to much trouble.
Just remember to bring a bag with all of the tools you will need to minimize climbing in and out.
Good luck, Marc The Last Chance 1979 C25 tr/fk #1481
I am shorter and heavier than Marc. I too climb into the large locker on a 1983 Catalina 25 to do electrical work. The cockpit space and volume is very large. Also, the bulkhead panel is removable between the locker and the quarters below the cockpit. I would save that trick for last.
Keep an insulated jug with some water within reach when working from inside the locker. If you were obese like me, you might want to step on a bucket or something further aft in the locker when climbing back out. It is not graceful for me and may not be lot's better for the smaller sailors. Use a bungee cord to keep the locker door all the way open. Plan this trek to assure that any meters, wire lugs, wire ties, etc. are handy. I store the safety, cleaning and some service gear in this area. Remove much of this stuff while inside and it is not too cozy. Do not stay too long inside if it is hot.
I just bought a 83 C25 and the PO did some wire splicing/connections that i would like to change and half of the fuses and switches are missing anyway. I removed the screws from the elec panel over the galley but the panel would not pull out far enough because of the wiring for me to see what wire went where. I am going to relocate the elec panel to over the left (i mean port) seat (i have traditional interior). I am thinking about running the wires from the existing elect panel thru a 3/4 inch pvc pipe along the top of stove counter to aft end of port seat where i will put my new elec panel. I would appreciate any comments from the old-timers on whether this is a good idea or not. I don't look forward to getting down in the lazerette to reconnect the wires but you gotta do what you gotta do.
Tim, You might consider, 1. Remove the shelf above the stove (4 screws), 2. Remove the water pump (handle and spigot are in the way, 3. And then tilt the bulkhead behind the sink forward (6-8 screws). This gives access to both the rear of the fuse panel and the wiring without having to try to fit into the locker. The bulkhead mounted light on my boat had slack to allow the panel to tilt. Similar to this (The bulkhead has been removed in this pict) <img src="http://home.bak.rr.com/edlgs/DSC00705.JPG" border=0>
I just moved my electrical panel to the starboard side, above the long bunk. All the wires can be run behind and below the companionway. I just wanted to be able to reach the switches from the "stairs" in a hurry. I'm adding a couple, for the radio, compass and pump while I'm at it. That I think will leave me with only a few lighting splices to make tight in the old location. In a 110 volt system it would be insanity to have the fusebox located directly over the sink... Stephen Z. on "Little Wing"
I have a 79 SK TR. It is a little awkward to get down in the port locker, but once you're there, it isn't so bad. I've been down in mine many times after the first time went easily.
I bought a bus bar. Solid brass bar about 10 inches long, and about 1 1/2 inches wide that has about 12-16 screws. This is used to combine all grounds. Good idea.
My boat's electrical had been N-rigged a few times by incompetant people, and nothing was marked. I redid almost everything.
Do this project at night with a helper that can hand you tools, and parts that you forget on topside. Nice and cool at night, and if you use a flashlight mounted on your head it all works out nice and easy.
