 Cutting into fiberglass???
sailgal
Initially Posted - 08/06/2003 :  11:03:40  Show Profile
I want to install a shore power inlet similiar to Als<img src="http://im1.shutterfly.com/procserv/47b3d803b3127cce899b542c5f600000001610" border=0>on the side of my sailboat.
My question is what type of tool to use to cut such a large round hole into the fiberglass. I was told in the past that you can send out cracks from your cutting site. What tips, or concerns can anyone provide me with this type of project. Thanks!
Suzie, Tropical Sleigh
<img src="http://im1.shutterfly.com/procserv/47b3da07b3127cce96a441e875780000001010" border=0>
WB #619 Sarasota FL.
Bryan Beamer
Response Posted - 08/06/2003 :  11:16:39  Show Profile
I use hole saws that can be purchased at any hardware store i.e. Lowes Home Depot.
I have installed cockpit speakers, a power inlet similar to what you are installing & a phone/cable inlet. They are easy to use and can be powered by a 1/2" chuck cordless drill.
The pilot bit on the hole saw is the most important part. Make sure it is a new heavy duty and sharp bit.
Bryan Beamer
<img src="http://im1.shutterfly.com/procserv/47b3d935b3127cce8ab87c3b48020000000010" border=0>
Daylight Again
C250wk #495
2003 National Champion
Dave B
Mali
Response Posted - 08/06/2003 :  11:17:28  Show Profile
Use a hole saw in a power drill. Drill a small pilot hole through the place where you want the hole, and use the hole to center the hole saw to cut part way in on both sides. Start VERY gently to spare the gelcoat around the hole. You should end up with a very clean, perfectly circular hole.
Bill Holcomb
Response Posted - 08/06/2003 :  11:36:23  Show Profile
Hi Suzie,
In addition to what Bryan and Dave have already posted, consider applying adhesive tape to the area you are going to cut the hole in. The tape helps reduce chipping of the gel coat as you start the hole.
Response Posted - 08/06/2003 :  13:37:33  Show Profile
You could practice cutting a couple of holes in a piece of masonite or similar material, to give you a little self-confidence before you make the cut in your fiberglass. Also, there are cheap hole saws and good quality hole saws. Get a good one for this job.
sailgal
Response Posted - 08/06/2003 :  15:10:44  Show Profile
Hole saw it is! Hope to get to this project over the weekend. Thanks guys!!
Sea Trac
Vanuatu
Response Posted - 08/06/2003 :  15:36:03  Show Profile
Suzie,
I'd also recommend that you wear safety goggles, a long sleeve shirt, and maybe even gloves. The fiberglass dust gets everywhere, and is especially painful in the eyes...especially if you where contacts!
J.B. Manley, Antares '85 FK/SR #4849
Grand Lake O' The Cherokees, NE Oklahoma
mday
Response Posted - 08/08/2003 :  01:30:28  Show Profile
Suzie,
I cut a large hole for my autohelm control unit with a hole saw too. It worked very nicely, but I used a heavy duty 1/2 inch drill. I'd highly recommend the "heavy" equipment. A 3/8 inch drill is a little light-weight for a big hole saw and you'll finding yourself fighting to keep the drill in line.
I didn't have any serious chipping around the front end of the hole and the back end was inside the bulkhead.
Good luck with the shore power install!
Max
Max Day
C250 WB 380
Lake Pleasant, AZ
Ben - FL
Response Posted - 08/09/2003 :  06:59:55  Show Profile  Visit Ben - FL's Homepage
Anytime I get near fiberglass, I use babypowder on my exposed skin to keep the fiberglass from itching. The powder fills up your skin pours so the glass cannot. It works great every time I have to get in an attic.
Safe voyages,
Ben, FL s/v Chick-a-pea C250wk
<img src="http://www.members.aol.com:/benraye/pictures/fullsail.jpg" border=0>
Response Posted - 08/14/2003 :  14:11:14  Show Profile
Bill always provides good advice and I agree fully about using some tape to cover the work area first. It will keep tools from scratching the surface and will retard flaking from the edge of the cut hole.
Steve is also right...there is considerable difference in quality of hole saws. A good arbor and hole saw can cost half a boat unit for a larger size hole. The arbor is a good investment but another idea is to hire a rigger to make your hole. He will have the hole saw and the cost may be the same as the purchase of the good tools.
Arlyn C-250 W/B #224
N/E Texas and Great Lakes
