 Drifter masthead setup
frog0911
Initially Posted - 10/17/2003 :  23:38:24  Show Profile
Any one have a diagram or pictures of the masthead setup for a drifter halyard? What size rope? What size block? Does it run inside or outside the mast? Thanks
Frog and The General
<img src="http://im1.shutterfly.com/procserv/47b3ce37b3127cce8061f98cd9170000001010" border=0>
04 Wing #743
Pretty Penny II
Response Posted - 10/18/2003 :  00:10:31  Show Profile
Frog... that would depend on which furler you have?
Arlyn C-250 W/B #224
<img src="http://www.cox-internet.com/arlynstewart/rr4.jpg" border=0>
N/E Texas and Great Lakes
[url="http://www.stewartfam.net/arlyn/"]Arlyn's C250 Mods n Cruising Stories[/url]
frog0911
Response Posted - 10/18/2003 :  06:50:51  Show Profile
The furler on Penny II is a snapfurl. The boat jib halyard is used on the sail from what I can tell. Any help will be greatly appreciated.
04 Wing #743
Pretty Penny II
Response Posted - 10/18/2003 :  08:53:13  Show Profile
I'm winging it a little with my advice about the snapfuler as I think it requires a method to lead the halyard back away from the furler to the mast. This is typically a block or fairlead of some sort down a short distance from the mast truck.
The drifter that has been produced by Ulman sails is a full dimension luff which it seems to me would have a problem dealing with the jib harlyard. I've raised this issue before and never got an answer on it so its likely not a problem or is dealt with in some way.
I would suggest discussing this with who ever makes your drifter. I see a couple of possibilities. If the sail has a full luff, it could be tacked like an asymmetrical ahead of the stay and handled by a spinnaker halyard mounted on a masthead crane (a forward extending attachment to the mast truck) in order to get the halyard forward enough to clear the furler.
The second method would use a drifter with a slightly shorter luff and require that the turning block that is used to turn the jib halyard aft to the mast be a double sheaved block to also accept the drifter halyard.
Have I made sense?
As far as the halyard size, quarter inch would work for a drifter halyard, the blocks would not need to be very heavy.
Edited by - arlyn stewart on 10/18/2003 09:02:22
frog0911
Response Posted - 10/18/2003 :  20:49:02  Show Profile
I understand some of it, but the rest is mush to me. I have a diagram of the masthead, but cannot figure out how to get it on a thread. I will EM to you and you can see the snapfurl setup.
04 Wing #743
Pretty Penny II
osmepneo
Response Posted - 10/19/2003 :  12:57:14  Show Profile
Frog, I have cdi-ff4 and when I use the drifter, I simply use the spinniker halyard, which is an internal halyard.
Don Peet
c25, 1665, osmepneo, sr/wk
<img src="http://im1.shutterfly.com/procserv/47b3ce31b3127cce8f8c0cbf1bca0000001010 " border=0>
The Great Sacandaga Lake, NY
On the hard
Response Posted - 10/19/2003 :  15:55:42  Show Profile
One more try at it with a pic....
<img src="http://www.stewartfam.net/arlyn/snap_furler.jpg" border=0>
frog0911
Response Posted - 10/19/2003 :  21:59:52  Show Profile
Got it all this time. As the saying goes "a picture is worth........". Thanks
04 Wing #743
Pretty Penny II
