 Semi-permanent pop top lift...
Initially Posted - 11/07/2003 :  22:44:12  Show Profile
I was wondering if anyone out there has 'permanently' raised their pop top by removing the parallelogram lift tubes and installing a 4" (or so) piece of trim all the way around between the coachroof and the pop top itself.
If done properly, it might look really nice and would improve cabin headroom to the coveted 6' mark.
After thinking about this, I'm somewhat surprised that some mfg didn't come out with this as a retrofit kit. Should be fairly simple to make and easy to install. If done properly, easy to remove too.
Hmmm... must ponder further.
WOTAM - '77 Catalina 25 SK/SR Sail Number 158
Rollins
Response Posted - 11/07/2003 :  23:31:11  Show Profile
Bruce:
I've wondered about this myself. I am 6'1, and with the pop-top up, the C25 has (according to the specs) 6'6" headroom. Makes you wonder if you might fashion some lumber with plexiglass windows, then tongue and groove the front corners. You could insert the boards and let the pop-top down on the trim boards. Then use some extensions on teh hold down bolts. You could probably even install the pneumatic lift kits in CD to help raise the top with the support braces removed.
I realize you probably would not want to sail with this installed; but when anchored out, or at the marina, it would be nice. And if one could make it with three (or four) connecting pieces of wood, you could store them in the cabin when not in use. On bigger boats, don't they call that a 'deck-salon' or something along those lines?
Let us know when you figure it out.
Mike
Response Posted - 11/08/2003 :  10:27:09  Show Profile  Visit Frank Hopper's Homepage
<br />I was wondering if anyone out there has 'permanently' raised their pop top by removing the parallelogram lift tubes and installing a 4" (or so) piece of trim all the way around between the coachroof and the pop top itself.
Would that make it a pilot house? Do it.
Response Posted - 11/08/2003 :  22:02:54  Show Profile
Somebody here used foam "noodle" swim toys from Walmart, I think, to hold the top up a little. Not a bad idea for a nice day when you want a some ventilation, and it might even be reasonable to sail that way.
Response Posted - 11/08/2003 :  22:52:52  Show Profile  Visit Frank Hopper's Homepage
I installed the power-lift kit from Catalina Direct the other day. They were emphatic that all pop-tops should have four dogs. Mine only has two. They seemed concerned that a boat would pop it's top in a knockdown. How many people have four? Did you add your own?
Would the structural foam that has been mentioned on this site work to make the solid walls that Clam wants to build? It would be easy to carve the needed grooves.
Response Posted - 11/08/2003 :  23:29:02  Show Profile
I think it would make a nice little 'pilothouse'. Maybe some square stainless or marine aluminum tubing for the framing... it would be pretty easy to roll the corners. Use smoked lexan or plexiglass for the sides & front with wood trim in between?
Have to take care that it wouldn't come out looking like a 26X though.
Bill Holcomb
Response Posted - 11/09/2003 :  12:08:23  Show Profile
The February 1991 issue of the Mainsheet magazine has an interesting article from a C25 owner, Gus Behling. He made up a four nesting 3/4" plywood pieces into two "poptop props" that will hold up the poptop about 5 or 6 inches. Since I was the Association Editor at the time, I also included the article in Volume II or the Catalina 25 Technical Manual.
It may be tough to find a copy of the Mainsheet, but as far as I know, both Volume II and the original Volume I Technical Manual are still available from the Association. These manuals are not the same as the Catalina Direct manual, and have allot of neat info regarding modifications, maintenance, etc. But, I don't remember anyone mentioning them lately.
BTW: If anyone decided to make their poptop C25 into a pilot house version, please bear in mind a couple of things: Safety, Safety, Safety, Does It Look Good.........After all, you are considering a major structural change to the boat.
Safety: There is every chance that people will sit and/or stand on the poptop. The "box" that holds up the poptop will be unsupported. So, you need to design for both compression as well as sideways loading. The "box" will really only have three sides - sort of like a free standing garage with a flat roof. So, a sturdy structure is needed.
Safety: For much of the same reason as above, thought should be given to heavy weather conditions. What loads can the "box" withstand if hit with a boarding sea or in a knockdown. If crew members are holding on to the poptop, will it stay in place or come loose? How will the whole structure be secured to the main cabin top?
Safety: Think carefully about how your new hatchboards will affix to the boat. Will they easily be blown out of the "box" in strong gusts? Will they keep water from entering the main cabin in a knockdown or if you get pooped?
Does it look good: Take a close look at other pilot house boats. Carefully sketch - or take photos of - the cabin and pilot house from all angles. Look carefully at things like - (1) Are the verticle sides actually verticle or are they angled? (2) Is the top layed horizontal, or is it angled down in front or back? (3) Do the portlights and windows match the rest of the boat's design? (4) Finally, does the pilot house add to or detract from the overall lines. In-other-words, would the boat look better with or without the pilot house?
Response Posted - 11/09/2003 :  15:29:25  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Bill Holcomb</i>
<br />Finally, does the pilot house add to or detract from the overall lines. In-other-words, would the boat look better with or without the pilot house?
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> In the photo gallery there are the pictures of the jaguar 25. I appears that they do not like pop-tops in the UK because none of the photos on our site or on the Jaguar site show a pop-top. Instead they show about a 4"rise in the coach roof makeing for much better permenant headroom with out the awkwardness of the pop-top contraption. Maybe that is the way to go. Have a look.
Chip Hunt
Response Posted - 11/10/2003 :  00:07:36  Show Profile
i would like to see some photos of this. i am also curious as to how the companionway would be closed up when the boat is not in use.
