 What anchor roller do you use?
Ben
Initially Posted - 12/03/2003 :  08:53:17  Show Profile
Hi all, I'm needing an anchor bow roller for Adventurous and I wanted to find out what ya'll recommend. The one I'm thinking of using is found on Sailnet for $60.00
http://www.sailnet.com/store/item.cfm?pid=17256&searchterm=WDEAR-3
Please tell me what you think. This is one of those "must buy items" before next season, because I'm tired of scratching my rub rail.
Thanks!
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
Response Posted - 12/03/2003 :  09:36:07  Show Profile  Visit Frank Hopper's Homepage
Because your boat has the long bow tang on the stem fitting you do not need the CD upgrade with roller, so I would think what you have picked is a good one.
Ed Montague
Response Posted - 12/03/2003 :  12:56:24  Show Profile
I have the same bow roller. Has worked well for the past 4 years. The only problem I have had with it (and this may be common with other makes) is the rubber roller doesn't roll very well and quickly wears out. I have replaced the roller every spring, easily found at West Marine. We anchor out frequently, I really appreciate the convenience of the bow roller.
RichardG
Response Posted - 12/03/2003 :  13:48:24  Show Profile
Ben:
A few years ago I bought a Windline AR-2 roller (the one you pictured is the AR-3) for $30. It helps greatly in protecting the rub rail while lowering/retrieving the anchor. It also helps greatly save my back by allowing me to use much stronger leg/butt muscles while pulling the anchor in (w/ 50' of heavy chain) from a sitting position with my feet in the anchor locker, a spot much more stable than leaning over the edge of the boat, especially on a pitching deck.
I think the advantage that $30 more gets you with the AR-3 is the "pin" which keeps the rode from popping out of the roller.
I haven't noticed the problem Ed describes with the roller, although to be honest I don't know if mine has stopped rolling.
eric.werkowitz
Response Posted - 12/03/2003 :  18:39:30  Show Profile
Ben,
Check this supplier out before you buy:
https://www.surplusunlimited.com/storefront.htm
Click on "anchor rollers" when the page comes up.
Eric Werkowitz
C25 #4969
Ben
Response Posted - 12/04/2003 :  07:28:26  Show Profile
Thanks for your input, everyone. The source Eric mentioned is the way I'm going to go, I think. Those anchor rollers are a lot less expensive.
Thanks again.
GeorgeB
Response Posted - 12/04/2003 :  15:07:18  Show Profile
Great prices for AM/FM radios also Thnaks!, Have you done business with them?
eric.werkowitz
Response Posted - 12/04/2003 :  18:11:28  Show Profile
George,
I have bought a number of items from Surplus Unlimited and have had no bad experiences.
Eric Werkowitz
C25 #4969
