 Rope Clutches
LeighMarie
Initially Posted - 01/26/2004 :  19:40:47  Show Profile
I am putting a plan together to finally run my main halyard, cunningham, boom vang and reefing line back to the cockpit. I'm going to put 2 on each side of the cabin top and am planning on using rope/line clutches. I went out and priced the blocks and deck organizers, and I can handle those. (I installed the mast plate from CD last year to be ready.) Then I priced the rope clutches. The Lewmar and Spinlocks are $99.95 each! These are for a double.
Would cam cleats work, as they are much less expensive? Or, should I just bite the bullet and buy 2 of them for a total of $200? It just seems a bit expensive. Actually, would just a cleat work? (Maybe I should just hang on to the main halyard while I'm sailing!) Just kidding!
Thanks!
Dave & Sharon on "Leigh-Marie"
Hull #5128
Response Posted - 01/26/2004 :  20:26:34  Show Profile
Dave,
Sailnet is having a little sale (aren't they always?) on [url="http://www.sailnet.com/store/departments.cfm?id=236"]rope clutches[/url]. They have a Spinlock XAS double for $75.61 (BoatUS $99.99). Their [url="http://www.sailnet.com/store/departments.cfm?id=265"]organizer[/url] prices aren't bad either.
Response Posted - 01/26/2004 :  20:27:27  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">(Maybe I should just hang on to the main halyard while I'm sailing!) Just kidding!<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Or, you could tie it around your waist.
I don't remember when rope clutches first appeared on the market, but when I first saw lines led aft to the cockpit, about 20 years ago, cam cleats were used.
The prices quoted by Don sound pretty good, though, and they would make an orderly and functional installation.
Edited by - Steve Milby on 01/26/2004 20:33:39
Sea Trac
Vanuatu
Response Posted - 01/26/2004 :  20:39:15  Show Profile
Dave,
I bought my Spinlock triples on Ebay for $80 each, so you might want to check there first. Personally, I wouldn't want to be without my line clutches.
Regards,
Response Posted - 01/26/2004 :  21:12:25  Show Profile
Dave & Sharon - on "This Side Up" I brought the vang, cunningham & reefing line along the port side to 2 cam cleats and a clam cleat (for the reefing line)installed at the end of the cabin top between the handrail and the sliding hatch (there is just enough room). On the stbd side I brought back all 3 halyards to a triple clutch and thence to a winch. The halyards, at times, really need a winch assist to hoist fully, and the clutch allows any one to be held while working the other)s).
Derek
Response Posted - 01/26/2004 :  21:39:48  Show Profile
I'm very pleased with my Garhauer line clutches.. Single $38.. Double $77.. Triple $116
Here's a link.
http://garhauermarine.com/catalog_process.cfm?cid=36
LeighMarie
Response Posted - 01/26/2004 :  21:56:39  Show Profile
Great information! Thanks for the help. It sounds like the right way (using clutches) is probably the best way. I'll go that route. I'll do some checking and see what kind of prices I can get. I'm going to Strictly Sail this weekend in Chicago. Can I get any better deals there?
teamwike
Response Posted - 01/26/2004 :  23:15:46  Show Profile
Derek,
Do all your halyards exit the stbd side of the mast? Or do you cross the front/back of the mast around the step?
Thank you,
Max in MD
Response Posted - 01/26/2004 :  23:31:58  Show Profile  Visit Frank Hopper's Homepage
Plan ahead, buy triples and stacked quads for the organizers, you can never have too many options.
http://homepage.mac.com/fhopper/PhotoAlbum37.html
Response Posted - 01/27/2004 :  00:27:40  Show Profile  Visit Leon Sisson's Homepage
Dave & Sharon,
I suggest you bite the bullet and go for Spinlock XAS triples. Like fhopper says, "you can never have too many options."
Here's what I've done, and a suggestion for saving a bit. I firmly believe that line clutches are justified for halyards and probably reefing lines on a 25' boat because of the potentially high loads. I installed a Spinlock XAS triple clutch and a stacked triple (6-sheeve) organizer on each side, and relocated the mast mounted Lewmar #7 winch to tension the two port headsail halyards. I routed the halyards, reefing lines, and (future) spinnaker tack downhaul to clutches through the lower level of organizer sheeves, which can handle slightly higher loads. However, the other mast control lines are lightly loaded enough that the upper level of organizer sheeves and camcleats will work, and so that's what I use for my 3:1 topping lift, 4:1 downhaul/cunningham, and 6:1 vang. (My 8:1 outhaul is controlled by a pivoting "head knocker" camcleat hanging from the boom.) If you do the arithmetic, yes, I have slightly more clutches than I'm using now. That came in very handy when one of them developed a hairline crack near the beginning of a month long cruise. At the damaged clutch group, I swapped the affected jib halyard with the currently unused spinnaker halyard. Presto, instant jury rig! No parts ordered or chased, no cash spent. Trip continued without delay or hassles!
Doing the lines lead aft upgrade right the first time can be expensive, but probably not as expensive and frustrating as doing it wrong the first time.
Response Posted - 01/27/2004 :  10:05:55  Show Profile
<br />. . . on "This Side Up" I brought the vang, cunningham & reefing line along the port side to 2 cam cleats and a clam cleat . . . On the stbd side I brought back all 3 halyards to a triple clutch and thence to a winch. The halyards, at times, really need a winch assist to hoist fully, and the clutch allows any one to be held while working the other)s).
Derek
Excellent advice/setup . . . the clutches also allow you to release really taunt halyards with minimal effort.
Response Posted - 01/27/2004 :  10:16:25  Show Profile
Max in MD - all my halyards (external) run thru' turning blocks on the stbd side of the mast step, and then turn thru' a triple organiser and back to the triple clutch.
Derek
John V.
Response Posted - 01/27/2004 :  12:09:26  Show Profile  Visit John V.'s Homepage
On Nin Bimash II I use two double rope clutches, a set on each side for halyards and lines that are set and left. For more active lines, boom vang and down haul I use harken cam cleats. the main halyard uses a larger turning block due to the higher load. The lines aft are from stb. to pt.: main halyard, reefing, down haul, boom vang, out haul, spinnaker halyard, and far to port on the cockpit combing the jib reefing/furling line. Catalina Direct sells a turning block plate that can be placed under the mast step. I found it very easy to install and removing the mast step gave opportunity to dry out the mast step area and to fill the dried out screw holes with epoxy. Re-bedding the step made me feel very confident in this rather critical point in the standing structure.
LeighMarie
Response Posted - 01/27/2004 :  13:06:25  Show Profile
John,
I installed that plate last year in preparation for doing what I hope to be doing. It was pretty easy to install, although I had to redrill some holes on it.
I also appreciate hearing your configuration. I'm going to run my main halyard and cunningham to the starboard and my boom vang and reefing line to the port. I have a furler where I just leave my jib halyard and don't need to run it back. I don't know if that's right to do with the jib halyard. I presume with a furler that you don't have to do anything with it once it's up. I do adjust tension on the forestay by using the backstay adjuster.
Anyway, that's how I hope to run things. I don't plan on putting on a winch. If I need one occasionally I can always run it to the jib winch.
John G-
Response Posted - 01/27/2004 :  14:04:17  Show Profile  Visit John G-'s Homepage
<font size="2"> <font face="Comic Sans MS">
I have [url="http://www.catalina25-250.org/tech/tech25/tt008.htm"] triple rope clutches [/url] on both sides of the cabin top. Unlike the description in the Tech Tips I now have the reefing line, topping lift and main halyard on the port side with a cabin top winch and main out haul and spinnaker halyard (in my case it’s a drifter halyard) on the starboard side without a winch.
IMO the triples will pay for themselves the first time you reef from the cockpit in under a minute when wind picks up.
Underlined words are a <b><font color="red">HOT</font id="red"></b> link.
</font id="size2"> </font id="Comic Sans MS">
John Mason
Response Posted - 01/27/2004 :  17:06:01  Show Profile
I added Easylock Mini clutches to the cabin top of my Cat25. I think Catalina Direct was selling those at the time.
Later I needed a triple and found them for a good price at http://www.stevestonmarine.com
Just checked the price, the single is $51.49US, double $93.28US, and triple $134.32US. Don't know if those are good prices anymore, but the clutches work great.
Response Posted - 01/27/2004 :  21:42:49  Show Profile
Also check with Catalina Direct about their prices on the XAS clutches--they have the singles, doubles, and triples, and I recall that they included the bolts, nuts and washers (sized for the C-25 coachroof). While I have two doubles, I suspect I only really need a clutch for my main halyard, because of the load. Cams would probably be sufficient for most other things. My furling jib halyard is "permanently" winched and cleated on the mast.
gnorgan
Response Posted - 01/27/2004 :  21:58:00  Show Profile
Dave, I agree with John. Buy triples and put them on both sides of cabin top. You can always add more lines led to cockpit later as you wish.
Note: Starboard side triple. Took the shot without all the lines run through.
LeighMarie
Response Posted - 01/27/2004 :  22:42:06  Show Profile
Gary, that is a great picture! I printed it off to give me some guidance. I originally intended to not install a cabin top winch, but after I get it all going I still may add it later on. I also have thought recently to not limit myself and going to a triple on both sides as it is cheaper to do it now than to do it later on. I would also then need to go to the triple deck organizer on both sides. It's all more expensive, but it's the right way to go in the long run.
John G-
Response Posted - 01/27/2004 :  22:49:45  Show Profile  Visit John G-'s Homepage
The best thing about the photo is the nice work Gary did on the teak.
Yes it is all more expensive but it really was why I bought “Peregrine” instead of the other C25’s I looked at. I singlehand most of the time and it makes for an easy boat to sail in a wide variety of conditions.
IMO you will make that money back and you will get the benefit of well rigged boat.
