Its one that gets epoxied I guess, mine fell off and I need to re-install it, but I've heard about the oil thing and wonder if it needs to be modified like that or if I should just use 5200 to mount it and be done.
From Garmin's instructions for installing a transom mount transducer inside the hull:
1. The hull must be solid fiberglass, not cored 2. The mounting surface must be smooth, clean, and as close to flat and level as possible. 3. Bed the transducer to the hull with silicone. The layer of silicone between the transducer and hull <i>must</i> be free of air bubbles or performance with be adversely affected.
I have heard of people using epoxy or 5200 to bed a transducer, but the problem with these compounds is that it is very difficult to remove the transducer without damaging it, if the location or installation doesn't work out and you need to move the unit. Voids or bubbles in the gelcoat or laminate that you can't see can result in poor performance, requiring you to move the transducer somewhere else; if it was bedded in epoxy, you will probably not be able to get it out of there intact. Using silicone as the bedding compound allows you to easily cut the transducer out with an Exacto knife or sharpened putty knife if you need to move it later.
