 Topping Lift Block
Initially Posted - 02/23/2004 :  08:05:58  Show Profile  Visit Champipple's Homepage
Sick of the pigtail!
We are planning on installing a topping lift. For those of you with blocks up on the masthead, can you tell me where you have yours attached?
Thanks.
dw
D. Wolff
DPO C25 Hull 401
Currently Sailing "Champagne and Ripple" 1982 O'day 30
Chief Measurer 2002-2006
Vice-commodore 2007
Response Posted - 02/23/2004 :  08:58:34  Show Profile
Duane,
Are you planning on having your topping lift setup start at the end of the boom, then go up to the masthead, and finally down along the mast to the cabon top?
Response Posted - 02/23/2004 :  09:41:17  Show Profile
As I recall.. on mine there is a 3/16" hole drilled through both sides of the aft masthead 'extension'... (about halfway back to where the backstay is attached). A stainless bolt with a nylon locking nut provides the attachment point for the topping lift block shackle.
Response Posted - 02/23/2004 :  10:05:26  Show Profile  Visit Frank Hopper's Homepage
While you can put a sheave through the clevis that supports the backstay, (I keep a spare sheave there myself)there is nothing to keep the line on the sheave at that location so a line would fall off and fall down to the clevis. SO, if you want to install a topping lift that runs down the mast then you will need to put a small block of there, much like installing a spinnaker halyard block on the front of the mast head only smaller. I now have three halyards that are run externally and adding a topping lift running down that crowded mast would be a mistake for me. If a person had internal halyards they might come to a differnt conclusion. I use the standard configuation of a topping lift terminating at the backstay clevis on the mast head and running through a block at the end of the boom. I have run mine on forward to the mast at the gooseneck and down to the cabin top.
Response Posted - 02/23/2004 :  10:08:35  Show Profile
Some things to consider...
I don't know if you race your boat, but having a topping lift block at the masthead means that your topping lift will both go up to and then down from the masthead putting twice as much line aloft as one would have with just a single line going up. Additionally, you also have the added weight of the block itself and as someone stated recently (Derek?), "a pound at the masthead is worth 50 at the rail".
If the topping lift line runs done the outside of the mast, you may end up with another line that will slap the mast when in port.
When adding a topping lift to my boat, I used the thimbled wire rope portion of the old halyard as part of the topping lift. One end of this wire rope is attached to the backstay clevis pin and the other thimbled end has a single block. The wire rope comes down to about 2 or 3 feet from the end of the boom. The rest of the setup involves regular line with a 2:1 purchase.
Response Posted - 02/23/2004 :  11:04:08  Show Profile  Visit Frank Hopper's Homepage
<br />Some things to consider...
That is a great tip, I think I will do that.
Response Posted - 02/23/2004 :  12:32:34  Show Profile
Don - that should be "a pound LESS at the masthead..."
Derek
Response Posted - 02/23/2004 :  12:38:04  Show Profile
<br />"a pound at the masthead is worth 50 at the rail".
Derek<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Of course!
Sea Trac
Vanuatu
Response Posted - 02/23/2004 :  13:40:21  Show Profile
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dlucier</i>
That's my set up, as well. I used 1/4" line and blocks. Even though I installed the adjustable topping lift two years ago, I just yesterday finally completed the project by cutting off the pigtail and its broken clip. Used my new Dremel (a guy really shouldn't have to wait until he's 41 to get a Dremel, tool cool!) to cut through, very carefully, the two compression fittings. Now, I can hank my anchor staysail on without having to stand on the stern pulpit rail on my tippy toes.
Response Posted - 02/23/2004 :  13:57:15  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Antares</i>
<br />...Used my new Dremel (a guy really shouldn't have to wait until he's 41 to get a Dremel, tool cool...
I'll second that on the Dremel...and coincidently, I turn 41 today!
I hope my wife hires a for the party!
Response Posted - 02/23/2004 :  14:21:03  Show Profile
. . . I turn 41 today! . . . I hope my wife hires a for the party!
Congrats Don!
My wife would say to <i>me</i> "With you here why would we need to <i>hire</i> a clown?"
Edited by - OJ on 02/23/2004 14:23:36
Sea Trac
Vanuatu
Response Posted - 02/23/2004 :  15:18:32  Show Profile
Congratulations, Don! ...and many more!
Response Posted - 02/23/2004 :  15:29:41  Show Profile
Congrats Don!
My wife would say to <i>me</i> "With you here why would we need to <i>hire</i> a clown?"<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
My wife would say the same about me!
<br />Congratulations, Don! ...and many more!<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Thanks!
MattL
Response Posted - 02/23/2004 :  15:51:47  Show Profile
Derek
[/quote]
Does that mean that when my wife calls me a fat head I actually look 50 lbs lighter around the waist?
