I acquired a 1982 C-25 this winter, moving up from a C-22. (I have a 22 for sale now). I read back through all the C-25 specific forums which are just super for information. Thanks to all of you for having this place to come to. I have a 9.9 Evinrude Sailmaster with a 91/4 x 8 prop. If I have absorbed the info I found here, That prop is 91/4 inches in diameter with a pitch of 8. What exactly does that 8 tell me? And If I gathered the info correctly, I would like to obtain (From My Local Dealer When Possible) a 91/2 to 10 by 5 to 51/2 prop. This would allow the 9.9 to still maintain hull speed but do a better job when it's rough or going into a strong headwind? Thank You, Jim Sherrow
Jim Sherrow "Bubbles" 1982 C-25 2876 SK/SR Lake Pomme De Terre, Missouri
The pitch (8) means that in one revolution, the blades will theoretically pull the prop through 8" of water (if there is no resistance). If the blades are flatter, they don't pull as far per revolution. The primary gain with the lower pitch is when starting and stopping around a dock. The higher pitch tends to act more like a paddle wheel, providing less directional thrust, and even tends to turn the water to froth. It is designed to push a lighter weight boat up to planing speed, which obviously it can't do with our boats. At cruising speed, both props will work--the low pitch will run at somewhat higher RPMs, which may actually be closer to the HP sweet-spot for a 2-stroke, but makes a little more noise. Against weather, it may have a slight advantage, but not as much as for starting and braking.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by km0e</i> <br />...I have a 9.9 Evinrude Sailmaster with a 9 1/4 x 8 prop. If I have absorbed the info I found here, that prop is 9 1/4 inches in diameter with a pitch of 8. What exactly does that 8 tell me?...<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
The "8" in the prop measurement refers to the theoretical forward movement of the propeller in one revolution.
