 Lamp replacement
Mike L
Initially Posted - 04/27/2004 :  15:52:45  Show Profile
I just bought a 1987 Catalina 25, which needs replacement bulbs (12V/10W) for the steaming light and anchor light. Both are identified as "GE-09" in the owner's manual, but nobody including West Marine seems to have such a lamp or a current part number. They're cylinder shaped, about an inch long with metal at both ends, and a dimple in the metal at each end. I don't want to install new fixtures instead of replacing the lamps. Can anyone help with a supplier for these lamps? Thanks.
Sea Trac
Vanuatu
Response Posted - 04/27/2004 :  15:58:24  Show Profile
Hi Mike,
Welcome to the fleet and the forum! I bought my replacement bulbs at West Marine. If I remember correctly the make and numbers didn't match, but they work just fine. Unfortunately, I can't remember the manufacturer, although it is the primary bulb supplier for WM. I'd suggest taking the bulbs with you to look for replacements.
Good luck!
Doug
Response Posted - 04/27/2004 :  15:58:38  Show Profile
Think I bought them at Shucks
Response Posted - 04/27/2004 :  16:05:27  Show Profile
Welcome to the fleet Mike...Does anyone have their C25 Handbook handy?...It may have it in there.
Buzz Maring
Response Posted - 04/27/2004 :  18:11:40  Show Profile
Hi Mike,
Welcome to the group!
<font color="blue">... I bought my replacement bulbs at West Marine. If I remember correctly the make and numbers didn't match, but they work just fine. - J.B.</font id="blue">
I did, too. As J.B. pointed out, the numbers didn't match, but West Marine did have replacement bulbs that worked. In fact, they had two different sizes ... they let me take a package of each and return the wrong size after I replaced the bad bulb.
I'm pretty sure I've seen similar bulbs in bass boat stores down here, too ... if your West Marine doesn't have anything close, you might try a place that sells stinkpots.
Good luck!
Response Posted - 04/27/2004 :  19:02:11  Show Profile
You might check you local auto parts store for these 12V bulbs.
