 Stern deck/hull joint trim
montl
Initially Posted - 05/17/2004 :  19:13:40  Show Profile
Read a post quite some time ago about the plastic trim piece that covers this joint directly above the top rudder gudgeon.
My plasic piece had weathered beyond repair, so I built a teak one.
I used a 3/4" teak board, a router to trim out the excess and then cut the shape out using the old piece as a pattern.
I am quite pleased with the result.
The holes are for the missing boarding ladder, to be upgraded before launch this spring.
Lloyd Montgomery
Morning Star #1838
Lloyd Montgomery
Morning Star #1838
Lake Diefenbaker, SK., Canada
Sea Trac
Vanuatu
Response Posted - 05/17/2004 :  19:26:05  Show Profile
Hi Lloyd,
Welcome to the forum and thank you very much for your post. I've currently been contemplating the same solution, and now it's assured.
Nice work!
Edited by - Sea Trac on 05/17/2004 19:41:03
Tony Dillon
Response Posted - 05/17/2004 :  19:28:44  Show Profile
Lloyd,
Very nice job!! Looks like an excellent and permenant fix to an ongoing problem.
Response Posted - 05/17/2004 :  22:14:57  Show Profile
Lloyd,
Nice job! and welcome to the forum.
I, too, contemplated putting a piece of teak back there when my plastic trim piece disintegrated.
Keep them ideas coming.
oldsalt
Response Posted - 05/17/2004 :  23:10:07  Show Profile
Why didn't I think of that? I've replaced several of the plastic trim pieces over the years only to have them crumble away. Your teak trim looks great and I'll be "borrowing" your neat idea. Thanks for the picture.
RoofRoof
Response Posted - 05/18/2004 :  10:57:06  Show Profile
The plastic trim piece I purchased doesn't even come close to fitting. Maybe it will fit someone else's boat. Assuming you don't want to make one out of teak.
Response Posted - 05/18/2004 :  11:44:24  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RoofRoof</i>
<br />The plastic trim piece I purchased doesn't even come close to fitting. Maybe it will fit someone else's boat. Assuming you don't want to make one out of teak.
The reason is doesn't come close to fitting is because it is also used on the C22, but needs to be trimmed for the C25.
Tony Dillon
Response Posted - 05/18/2004 :  14:22:02  Show Profile
Its not hard to trim one (a plastic one) to fit, but if I am going to invest the time and effort the next time I am going to follow Lloyd's lead and make a teak one.
