 What the Surveyor Missed
reuben
Initially Posted - 06/01/2004 :  09:31:12  Show Profile
I knew he wasn't going to run the outboard, because he did the survey in January when it was below zero. We talked about this, and I okayed it. But he apparently didn't try to raise & lower the motor, either, because I learned last week the swivel mount is broken. It won't lock in either the up or down position, and repairs are very likely going to cost me as much as the survey did. Do I have recourse in this situation?
Reuben
C-250 WK #499
Bayfield, WI
Response Posted - 06/01/2004 :  10:06:41  Show Profile
I'm sorry you're having that problem. Recently, I asked a knowledgeable yacht broker about the extent of liability of a surveyor. He said the surveyor is not an insurer, and is therefore not liable for every oversight. He implied that they have no liability at all. I doubt that. I suspect they would be liable only for <u>gross</u> negligence ("wilful and wanton misconduct"), as opposed to <u>ordinary</u> negligence (mere oversight) in performing the survey. In your case, however, the surveyor is likely to claim that you excused him from examining the motor, and, since that was probably oral and unrecorded, you would probably have a problem of proof.
Involving an attorney would cost more than the dispute justifies. You could file a small claim in a local court, but, to be honest, it would be an uphill battle. Sometimes it's best to just bite the bullet and go sailing. It'll ease the pain.
