 Fast Ablative Paint?
Bruce Baker
Initially Posted - 07/14/2004 :  15:06:20  Show Profile
Because of time constraints (and not wishing to miss the heart of the sailing season) I'm going to put a coat of abalative paint over the existing paint. Obviously, this will be slower than a VC-17 teflon paint. Are all ablative paints the same? Are some faster than others?
Bruce Baker
Falls Church, VA
"Yee Ha" 3573
'83SR/SK
jtbarrett
Response Posted - 07/14/2004 :  15:24:52  Show Profile
Micron biolux is good for slime like in the potomac. Also for a quick job, you could WET SAND the bottom, then apply the paint. Wet sand meaning spray the bottom with a hose and nozzle, then take sand paper for wet applications attached to a dry wallers sanding stick (keep the bottom damp). It's a quick light sanding job. Also while out of the water if time permits a nice hull wax job with teflon wax would help.
Jonathan T Barrett
#3047 SR SK '82
"hang Loose"
Bruce Baker
Response Posted - 07/14/2004 :  15:48:15  Show Profile
Thanks, Jonathan. I much prefer wet sanding over dry.
I'll definitely give the boat a coat of Teflon wax. The StarBrite brand looks good.
Response Posted - 07/14/2004 :  23:49:57  Show Profile
Teflon above the waterline to make her faster... Do you guys also by kryptonite-shafted golf clubs?
Bruce Baker
Response Posted - 07/15/2004 :  09:54:29  Show Profile
Dave,
If Teflon bottom paint can make a boat faster, it seem logical that teflon wax on the sides can also make the boat faster. After all, "above the water line" is a relative concept. When the boat heels over, a lot of the sides are in the water.
As for the kryptonite shaft golf clubs: I don't play golf. I plan to take it up when I'm too old to sail--maybe when I'm 75 or so:)
jtbarrett
Response Posted - 07/15/2004 :  15:29:48  Show Profile
Dave there are reasons SEA DOG (Doug Andersons) catalina 25 seem to win high point on the Rappahanock River off the Chesapeake Bay the past 2 years and in good shape again this year. Yes, waxing the hull helps..like a swimmer shaves his body hair smooth.. Oh the Cat25 has beaten a Cat 320 through the water, funny how they didn't come back to race the second race .
Jonathan T Barrett
"Hang Loose"
'82 SK SR #3047
