My 1982 Catalina 25 is looking pretty good, but I'm getting nervous about the keel bolts. What I can see looks pretty corroded, and I just don't like to think about short choppy seas. How much of a job would it be to replace these bolts? Are there any alternatives, e.g., using epoxy in lieu of the (wasted) nuts?
A forum & archive search on 'keel bolts' should turn up some thread(s) on that topic. (no pun intended) I know that one or more of our members have done this.
I had new keel bolts put into my 1978 fin keel. This is a cast iron keel. Its a job for a professional. The old bolts were rusted to the size of a #2 pencil. They removed the pop-top, set up a big portable drill press across the deck, and drilled 6 new holes through the keel well into the keel, threaded them, and inserted 6 new 3/4 inch stainless steel bolts 6 inches into the cast iron. Stainless nuts were then added. The old rusted bolts were treated with Carbolic acid. This transforms the rust into something very hard, then sealed with Bitumen (like asphalt+epoxy).
Cost $900. Done in the slip. Took 2 weeks (it takes a long time to bore a hole in cast iron). If your in Southern CA I can give you the name of the guy, keel bolt repairs is all he does.
I'm very happy with the job. The old bolts are still holding and the new ones, well, I don't have to worry about the keel for another 25 years.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Laux</i> <br />Which keel configuration do you have? Dave <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I'm assuming lead, but it might be cast iron. Configuration: fin keel, fixed.
Check with Catalina customer service to see if you have a lead or fin keel. They told me that they sell lag bolts that you can screw into a lead keel. Frank Butler said, at the Atlantic City Boat Show, that my keel ('79) is cast iron, but that they switched to lead later, but I don't know how much later. I have not replaced the bolts. Just used Rustoleum Rust Reformer, primed and painted with bright yellow rustoleum. They haven't deteriorated further, at least not that I can see.
Dave Gabel Walkure '79 tall rig fixed keel hull # 1484
Fred. Its not rocket science to figure out which keel material you have. When the boat is out of the water take a file to it or look at where it has been recently scraped. If its iron you could either drop the ballast, put in new bolts in the old holes, sand blast and epoxy coat the keel, or go the route that Jim did. If its lead the same two options apply but you might not need the sandblasting. You can drill and tap lead or use lag screws but the other consideration you will have to look at is the condition of the stub fiberglass and the core material if any in your boat. Dave
From what I've seen and heard, if you have mild steel (rusty) bolts and nuts in a C-25, you have a cast iron keel. If you see original stainless steel (shiny) nuts and bolts, you have the lead keel. Out of the water, the cast iron almost always has some obvious rust (except on a few boats where the owners have primed them and overcoated with epoxy), while the lead is completely encased in fairly thick fiberglass--that's what I have. I think Catalina switched to lead around 1984, maybe '83. Generally (although I can't vouch for the C-25), a lead keel is made by pouring the lead around a set of inverted stainless bolts, with the heads down inside the casting. They aren't pulling out, although you could worry about crevice corrosion. (Somebody let me know if your stainless keel bolts break and your fin keel drops off--if you live to tell!)
If your boat has mild steel keel bolts it has a cast iron keel as well. The lead keels are fastened with stainless bolts and nuts and I believe my '83 is among the first of the lead keeled variants. The stainless bolts on my boat look as new as the day she was built. You can check your keel with a magnet to determin wwhat it's made of but I believe that 82s have cast iron keels.
Fred, assuming the guys are right and you have a cast iron keel and mild steel bolts, if it was my boat I would wait til winter haul out time and remove the keel from the boat. The build up of corroision material betweeen the keel and the hull and the potential for damage to the keel stub is high and simple bolt addition does not deal with any of those problems. Also this is mostly a do it yourself project where drilling in place may not be. The problem may not be the bad nuts it may be the condition of the bolts down where you cannot see them inside the keel fiberglass. The other place to inspect carefully is the joint between the keel and the hull. If its showing an opening and rusty water is coming out I would be more worried, if its tight and clean I would be less worried. Dave
