 Which Winch?
centurion
Initially Posted - 01/02/2005 :  16:13:55  Show Profile  Visit centurion's Homepage
I am planning on rigging my C25 with a cabin top winch for raising the mainsail. I have access to a Lewmar #6 and #8. Would the #6 be big enough or should I use the #8? (We just moved up to the C25 from a Venture 17 with NO winches, so I'm not experienced in this area...yet).
Response Posted - 01/02/2005 :  18:58:19  Show Profile  Visit aeckhart's Homepage
I believe the stock cabin top winch was a Lewmar #6 single speed. Although tempting, I don't think you need any bigger than that on the cabin top. Number sixteen self-tailers would be nice for the primary's though.
Al
GALLIVANT #5801
lcharlot
Antigua and Barbuda
Response Posted - 01/02/2005 :  19:49:49  Show Profile
Concur with Al's opinion. Lewmar #6 is the standard Catalina 25 halyard winch, and it's got more than enough "power" to raise and adequately tighten the luff on a mainsail with even a short 6" winch handle. If it takes a huge amount of effort to hoist the sail, the slides and the mast slot are probably dirty or sticking and you should clean and lubricate them with "SailKote" or a similar product. Use of excessive force is liable to break the slugs if they are the cheap plastic-only kind without a metal loop. The standard primary winches are Lewmar #7 or #16ST, so your Lewmar #8 is larger than even the primary winches need to be on a Cat 25.
Oscar
Response Posted - 01/03/2005 :  08:47:49  Show Profile  Visit Oscar's Homepage
Second the clean and lube. You should be able to raise the sail by hand, then use the winch to tension the luff.
Oscar
C42 # 76 "Lady Kay" (Ex. C250 WB #618 )
Georgetown MD/Fort Lauderdale FL
