 O/B motor help
77Gypsy
Initially Posted - 03/17/2005 :  20:24:53  Show Profile
I'm attempting to use my motor after 1 1/2 years of not using it. it is a 2000 Honda 9.9 4 stroke.
Is there anything i should do to make sure it will be in good running order for this season? gas treatments, carb cleaner, oil, etc.
Steve
78 C25 SR/FK - Gypsy
Response Posted - 03/17/2005 :  21:01:00  Show Profile
Here's what I'd do.
Dump your old fuel into another can and use it for your old lawnmower. Newer Hondas are really sensitive to fuel quality and cleanliness.
Change engine oil.
Change lower end oil
Give all grease fittings a spritz.
Inspect and renew spark plugs needed
Inspect fuel hose, fittings and tank.
Pull propellor and inspect shaft seal.
Run the engine on a stand using a flushing
fitting or a barrel well BEFORE launch day.
Response Posted - 03/19/2005 :  08:44:21  Show Profile
Clam, I wouldn't even put that gas into an old Briggs-Stratton... But to your list, I would add: If the cylinders weren't "fogged" before the engine was laid up, I'd do it now before turning it over, to avoid the effects of dry rings against the cylinder walls. It'll cause a little puff of smoke the first time you start the engine. Marine stores have "fogging spray".
