 First Try
Ed Montague
Initially Posted - 04/04/2002 :  17:42:40  Show Profile
Matt and I have been slow on the photo posting skill and Mark Maxwell was kind enough to send me blow by blow directions on how to it. So hopefully you will be able to see Yahoo sitting in Sydney, Vancouver Island. If not just use your imagination.<img src="http://im1.shutterfly.com/procserv/47b2da25b3127cce9d6f980242880000004010" border=0> OK, I see by the preview that you need a magnifying glass to see. Next problem to solve.
Ed Montague on 'Yahoo'
Mark Maxwell
Response Posted - 04/04/2002 :  18:22:47  Show Profile
Hi Ed,
Well your on the right track. <img src=icon_smile.gif border=0 align=middle> All you did was put the link to the thumbnail picture. If you want the big one just double click it. Then do everything the same way as you did this time and the larger picture will show up like this. <img src="http://im1.shutterfly.com/procserv/47b2da25b3127cce9d6f980242880000004410" border=0> Have Fun.
ps. Nice looking boat <img src=icon_smile.gif border=0 align=middle>
Mark-
<img src="http://personal.jax.bellsouth.net/jax/l/c/lchaplin/unkarock/usflagwav.gif" border=0>
'Impulse'
C25 #533 DINN/FIN
Bristle
Response Posted - 04/04/2002 :  18:47:45  Show Profile
Ya, Ed--especially compared to the one in front of you! I particularly like your stern rail, and need to modify mine in about the same way. Is there any particular reasoning on how high the new, lower cross-bar between the transom stanchions should be (or how low it can be)? Is there any bow (toward the stern) in your new cross-bar? Who did the modification? (Not that I'll be able to get that person to do mine in CT...)
Ed Montague
Response Posted - 04/04/2002 :  19:26:16  Show Profile
Thanks again Mark!!!<img src=icon_smile_approve.gif border=0 align=middle>
Dave, to do this stern rail change you will need a good hack saw or 4" angle grinder with a cut off disk. You will also need to purchase two SS el's and two SS t's of the proper size to match your pulpit tubing. I can't remember the tube size off hand. First, you cut the top rail section between the two rear vertical peices out. This peice will be used later. You will need to trim the junction left back just far enough to allow the SS el's to be put on creating a nice clean connection. You then decide where you want to place the cross bar down between the verticals and cut the verticals accordingly. This is where the SS t's are placed. The new (old) cross peice goes between. These SS fittings can be purchased at WM or other marine supply. They have allen screws to hold them onto the tubing. I cranked them down hard and used a little epoxy. This didn't hold too well so I tack welded them. The lower cross bar allows me to use the stern ladder without the either stooping or climbing. The stern ladder is a secondary ladder. The whole project took about 45 minutes not including dragging out the wire welder.
Ed Montague
Response Posted - 04/04/2002 :  19:40:09  Show Profile
Another view.<img src="http://im1.shutterfly.com/procserv/47b2da25b3127cce9d6f268542500000004410" border=0>
MattL
Response Posted - 04/04/2002 :  23:51:26  Show Profile
Hi Ed,
The photos look great. I just got the ones I took of Don Pedro today and I have been trying to think of the best way to get copies to you. If you would like I can snail mail them to you, send me the address. Or you can wait a little while because as I logged on to compuserve today they offered a flatbed scanner for 4 easy payments of $24.99 and Brigitte said "go ahead". We did go antiquing today and she may be feeling a little guilty.
I got a couple of good panarama shots showing your marina and one of the rain bombarding the water and us.
Is there any way I could persuade Marke to send me the blow by blow description on how to get the photos lined up?
After seeing the nice finish you had on your teak I picked up a little of the cetol at west marine (took the vet with the top down, nice sun burn), also got a cheak block to set up a new outhaul. As I took the hatch rails off to do a better job I found that one lip was almost all the way busted off. Got out the grinder and fiberglass and fixed. Well have to put a little on the other side of the layer still.
Two boats on the water at our lake so I hope to be out there pronto.
Matt
EC Rider
Cat 25 86'
FK SR
Response Posted - 04/05/2002 :  00:58:04  Show Profile
Ed,
Nice shot of the autopilot. I just received mine from Sailnet yesterday and I'm still on cloud nine. Question, What's that blue cover with wires coming from it underneath the tiller? Compass? Nice pics!
Don Lucier, Northstar
C25 SR/FK
Ed Montague
Response Posted - 04/05/2002 :  02:40:49  Show Profile
Don, The blue cover protects my fishfinder/depth finder. I like this location, it's out of the way and easy to see. The wiring runs into the lazzarett. I will probably go through the liner just behind the unit into the space between the liner and transom next time I replace it. My puck is mounted to shoot through the hull under the forward area of the quarter berth.
You might also notice that I have hinged my tiller just forward of the autohelm pin. This way I can flip the unneeded part of the tiller out of the way when using the autohelm in a crowded cockpit.
<img src="http://im1.shutterfly.com/procserv/47b2da25b3127cce9d686f9e62220000004410" border=0>
Response Posted - 04/05/2002 :  02:47:24  Show Profile
Cooool tiller idea!<img src=icon_smile_cool.gif border=0 align=middle>
C25 SR/FK
Doug L
Response Posted - 04/05/2002 :  09:49:36  Show Profile
Hi Ed,
I would like to read that article on the folding tiller, but its too small, and unclear. Printing it out didn't help either. Also, why did you mount your autopilot on the portside? I've done all the wiring for my autohelm, and am about ready to install it.
Thanks, Doug
Doug L 1980 SK #1848
Bristle
Response Posted - 04/05/2002 :  09:57:29  Show Profile
Must be nice... If I used an autohelm, I'd bring back at least 4-5 lobster pots every time out--if I could tow them all!
Response Posted - 04/05/2002 :  12:26:47  Show Profile
Doug,
I, too, just received my autopilot and I've been debating the pros and cons of a port or starboard mount. Of the photos I've seen, and it makes sense, the autopilot has been mounted on the side of the cockpit opposite of the motor. If you are using the autopilot while motoring, adjustments can be made to the motor(speed direction), without tripping over the autopilot.
C25 SR/FK
Ed Montague
Response Posted - 04/05/2002 :  19:14:14  Show Profile
Don, My motor is on the starboard side and the autohelm (called Scotty) is on the port side. You are correct, the autohelm will be in the way of the motor controls if the two are on the same side.
Doug, I have e mailed a copy of the article to you. I think that it will be too big this time.
Dave, Do you need a commercial fishing license to gather lobster in this manner?
<img src=icon_smile_wink.gif border=0 align=middle>
Response Posted - 04/05/2002 :  19:21:14  Show Profile
Ed,
Shouldn't your engine be named "Scotty", the autohelm "Sulu", the radio "Uhura", first aid kit "Bones"......
C25 SR/FK
Doug L
Response Posted - 04/05/2002 :  21:51:17  Show Profile
Don and Ed,
Of course, autopilot opposite the motor...it makes sense. I lucked out; my motor is on the portside(which I understand is not the best for weight distribution)and I had already wired my autohelm for the starboard side. Now, I just have to decide how I want to mount it. Ed, yours is up higher than others I've seen photo's of, but it looks good and sturdy...oh, and thanks for the tiller article.
Doug
Response Posted - 04/05/2002 :  22:00:53  Show Profile
Doug,
Have you seen this link from Albert?
http://www.catalina25-250.org/forum/topic.asp?TOPIC_ID=755
C25 SR/FK
Doug L
Response Posted - 04/05/2002 :  23:54:15  Show Profile
Yes, and I used Albert's idea of using the coaming box for sockets. I just need to decide if I want to shell out another $60 for the cantilever bracket, or try and mount using the pin included with the unit, and put it on top of the coaming. But then, I guess I need an extension on the autohelm pushrod...decisions, decisions...
Doug
Doug L C25SK #1848
Ed Montague
Response Posted - 04/06/2002 :  00:35:41  Show Profile
Don, It goes like this "Beam me out of here <u>Scotty</u>, there's no intelligent life here!!!"<img src=icon_smile_clown.gif border=0 align=middle>
Response Posted - 04/06/2002 :  01:13:22  Show Profile
"Live Long and Prosper"
C25 SR/FK
