 Where is bilge pump?
moserd
Initially Posted - 05/22/2005 :  23:22:24  Show Profile
According to my user's manual (2005 WK) the manual bilge pump pick up should be in the aft centerline bilge sump (under the aft berth). I don't seem to be able to locate what I would expect to be a bilge pump pickup hose. I do find a thru hull (my boat has the marine head installed) and a valve for the head intake water in this location. I would like to test this pump but am not sure where to 'put' water to check it out. Anyone have an idea(s)?
Don
Don Moser
Jim Mc
Response Posted - 05/23/2005 :  00:18:01  Show Profile
On my 2000 WK the bilge pump hose is located under the cabin table. There is a plywood cover over the bilge at that point. You should also see the keel bolts at the same location. The only fitting I have under the aft berth is the through hull shut off valve for the marine head.
Dkn420
Response Posted - 05/23/2005 :  00:48:01  Show Profile
Ditto on my 2004 WK...Dan #727
Jeff McK
Response Posted - 05/23/2005 :  19:51:53  Show Profile
When you lift the panel over the keel bolts & bilge, look aft of the opening & under the floor for a gray 1 1/2" hose (looks like an undersized vacuum cleaner hose). That's where mine was when it arrived from the factory. It's a simple task to pull it into the right place.
Once you are set, throw a couple of cups of water in the bilge & pump away.
moserd
Response Posted - 05/23/2005 :  22:36:54  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Jeff McK</i>
<br />When you lift the panel over the keel bolts & bilge, look aft of the opening & under the floor for a gray 1 1/2" hose (looks like an undersized vacuum cleaner hose). That's where mine was when it arrived from the factory. It's a simple task to pull it into the right place.
Thanks, I'll take a look aft in the bilge, I'll bet you are correct and the hose is still 'stuffed' out of site. I love this forum, nothing like taking advantage of others knowledge!
Don
Took a closer look while at the lake today, your were correct, the hose was just where you said it would be, pump works fine!
Edited by - moserd on 05/29/2005 22:20:48
Lightnup
Response Posted - 05/23/2005 :  22:52:40  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">...nothing like taking advantage of others knowledge!
Isn't that what Martha Stewart...oh, never mind.
Steve
