Opinion of this forum, factory manual and personal experience is that anything over 10 hp is useless. I run with my 9.9 at about 2/3 to 3/4 throttle and find that more power burns more fuel with little gain on my GPS.
8HP is usually enough, more than 10HP is over kill. I have a Yamaha 9.9HP extra long shaft high thrust elec.start, and am very happy with it. More important than raw HP is extra long shaft and high thrust prop.
There's a fellow here in Port Isabel, Tx that keeps his C25 in Bristol fashion, but has a 30hp o/b on it. Says he needs it to tow the kids on various floating toys. Otherwise they don't enjoy going out on the boat. I wonder that the transom hasn't fallen off. He said he also has a 15hp for normal ops.
6 or even 5 HP will do the job. Extra long shaft, thats the key. Don't agree with the need for a high thrust prop. In my opinion those are for power boats using them as kickers. I beleive a standard prop will get you better MPG (although the high thrust will reverse and stop much better).
I took off my 8 HP honda and ran around with my 3.5 HP Mercury 2 stroke and it works great in sheltered water.
Unfortunately, no 5s and 6s that I've heard of come with extra-long shafts. Honda and Yamaha 8s do, and are quiet, smooth, and fairly fuel-efficient, but HEAVY. Nissan's 9.8 4-stroke offers the XLS, and is lighter (by about 20 lbs. based on the claims), making it the new favorite here (keeping in mind that it's new).
The 8 hp Hondas and Yamahas have ample power, and as stated above, the high-thrust prop on both is great for stopping and backing up, but requires slightly higher RPMs at cruising speed. I cruise at about 5.5 knots at a little above half throttle with my Honda 8--more throttle increases the speed a little and decreases the gas mileage. The 9.9 Honda is the <i>same engine</i> as the 8, but a couple of boat units more expensive for a few RPMs that cannot be used to any advantage on a C-25. Anybody's 15 is just more of a waste of weight, gas, and probably purchase price.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DanM</i> <br />Yes, Charlie. 20 inches=Long, 25 inches=XtraLong. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> Except for the Nissan/Tohatsu line where the long shaft is actually 23". Not sure about the XLong.
I have a long shaft 15HP on my boat, but only because it was what was available in my price range, CHEAP! A little old man used it on sundays to go fishing...For real! And only for one season. Basiclly a brand new engine and at only $995.00 it was a steal. As for the extra HP. The boat goes 5.5 with or with out the extra 5HP. If I had my choice the 9.9 is the way to go, unless you can find a little old man in you marina...:D BTW, I'm told that the 9.9 and the 15HP Merc weigh the same....
With some brands like Merc and OMC, 2 cycle 9.9s and 15s are the same engine with the 9.9 being detuned for lower revs and HP. but I don't believe that extra long shafts were available in 15HP.
