Got a few projects off the list on Sunday. First we mounted the Magma grill. We chose to mount it off the mid stern rail where the Nauti Duck Helmsman's Seat can act as a prep surface.
Next up was to install the Edson Wheel Brake. It was a simple install and really will help to hold the wheel when I need to make sail adjustments, etc. Typical Edson gear - expensive but well engineered and built and with good directions. 30 minutes from start to completion.
Finally, and the most complex, was to install the CDI ball bearings kit in the furler drum. Definitely would have been easier with the rig down but we got the job done without losing any parts in the lake!! Another well-built item and good set of directions. One hour total on this and, again, good directions.
We'll get to use the furler in the next day or two but I could tell immediately that it will make a big difference.
Sorry, no photos of the wheel brake and ball bearings. I meant to take pix but then got caught up in the doing of the projects. When I told Pat that I meant to take photos and that perhaps we could re-do the ball bearing install and take pictures she gave me that special look....
You'll like your grill there, that's where we put ours as well.
I think pretty much every guy who's married or has a significant other knows "that" look. Rita has several versions of it, from "amused" through "I'm not speaking to you right now".
Randi, Let me know how the brake works for handling lines on gusty days. Its on one of my chief priority lists, but right now I have no shortage of crew, and need to find a dingy (cheap). Also with the amount of time I spend grappling the wheel, I'm not sure it would be all that effective.
FYI, since we figured out how to balance the boat sail trim, we now can put the boat on course, trim the sails, lock down the wheel and leave it unadjusted for what seems forever, 15 mins is normal.
Note: We now harden the backstay, have tuned the rigging as per Arlyn's instructions, and having just completed the repair of the steering system which included removing most of the slack between wheel and rudder, it seems even easier to setup the brake and take one!
The grill looks exactly like mine and place at the exact same spot except mine is about 6 inches higher and I cook sitting on the starboard catbird seat. All I need now is a beer holder to starboard and a 50" plasma in front of me.
Try cooking those big spicy sausages they come out great on that grill.
Edited by - Steve Blackburn on 05/26/2009 21:57:58
I have the same type of grill. Maybe not the exact grill but close. The only thing I don't like is that when the wind is up a bit I have a hard time keeping it lit. But then I just whip out the propane or butane stove.
(to the voice of Homer Simpson)MMMMMMMmmmmmmmmmmm, <i>grilled sweet potato</i>
Dave, I had that same Force 10 stove and I finally replaced it with the Magma. My Force 10 just would not stay lit in any decent wind. Drove us crazy. I hope the Magma works better!
Randy, just to play the Devils advocate, as I have seen a couple of BBQ fires, I would be concerned to having it near motor and fuel locker. I have mine on catbird seats and still worry about fire. Steve A
