On my 89 I have the balanced foam core rudder I believe. A month ago I removed it to replace a broken pintle and noticed it had a couple penetrating oyster (I'm guessing) scrubs on the bottom and a ding/crack on the back edge below the water line and it was leaching water. So I drilled some holes in the bottom and left it in my garage to drain and dry. Yesterday I got some epoxy and picked up the rudder to bring it to the shop to repair. When I got to the shop and picked it up out of the the back of my car I notice that the crack on the back edge looked damp. Turned it back side down and water started dripping out. Wow! I guess with the foam core it can harbor water in different places that doesn't necessarily find it's way down and out.
Do I even need to worry about a small amount of water in this type rudder? Can I just dry the area and seal it up? Thanks for your advice!
Dave Robbins PO to*Bamboo* '89 SR/WK #5877 Daytona Bch., FL
If you do a search of the forum you will find dozens of threads on this exact topic including many with detailed explanations of repairs, info on replacement, safety concerns, etc.
I think the water between the hard foam core and the fiberglass and gelcoat shell can do no good. When the rudder heats and cools each day, that water will create pressure in the small closed spaces that could only tend to make cracks worse.
I bet it's best to purge the water. You could turn it upside down and inject or pour as much acetone as possible down into the holes you've made, turning the rudder over and over so it reaches any gaps inside, and then dumping it out and repeating the acetone rinse out.
Finally heating the thing up in the sun while turning it over at variouis angles a few times an hour would evaporate the acetone completely.
Then you could fill in the gaps with the penetrating epoxy stuff you know about and seal it the holes.
Good luck with your repair.
Before doing any of this, I would call Catalina and ask whether the foam core is compatible with acetone. You wouldn't want to dissolve the foam core!
The threads I've seen dealt with wood core rudders I think Ryan, don't recall seeing any about foam cores. And John I don't think my problem is that bad, it's only drained an ounce or two and feels very strong. I think I'll just let it drain and patch it.
It's ruined and worthless. You'll have to replace it completely with a whole new rudder. I'll take it off your hands though so you don't have to worry with throwing it away. I'll even pay for shipping.
I agree your problem shouldn't be severe. You don't have to worry about freezing--other than that, water expands by only about 1-2% from just above freezing to near boiling. I suspect many of these rudders get some moisture inside, from the pintles or the tiller hole or whatever, like the old ones did... That's why I always stored mine inside over the winter. And the reason acetone only comes in metal cans is it dissolves most kinds of polymers, except during a very brief wiping-down.
I wouldn't use Acetone, It might dissolve/melt the foam. Maybe alcohol is a better bet. I can't imagine that they build the rudder with open cell foam. ( Absorbs water ) I would hope that they use closed cell foam ( won't absorb water like the foam floats used under finger docks or surfboards ) You might just have some pockets of water between the foam and the shell. Maybe some heat lamps to warm the rudder for a few days would dry it up. I also repaired my balanced rudder with G-Flex, Excellent product for the rudder.
Bring the rudder to Nashville for a few days. When we got home today the temp was in the upper 90's with a heat index of 111 degrees. And I thought Mobile was hot!
