I don't know if it will work on a C250, but the arrangement I use on my C&C 35 is that I attach a snatch block to each stern dock cleat. Then I lead the spin sheet through the block and bring it forward and wrap it around my primary winch. My primary winches are self tailing, so I use the self tailers to cleat the line. Thus, I use the same winches for the spinnaker that I use for the Genoa. The way I attach the snatch blocks to the cleats is that I tied a small loop in a short piece of line, shackle the block to the loop, and then attach the loop to the dock cleat. It's simple and works fine. You can buy pre-made loops for the purpose, but the last time I priced them, they cost $60.00.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i> <br />Leading the lines fwd to the winches sounds good ( right price. ) <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> That's what appealed to me about it. Having an extra pair of winches might be worthwhile on some boats for racing, but for a cruiser, using the primaries for a spinnaker is entirely satisfactory. Also, on a smaller boat, with a smaller cockpit, you just don't have enough room for extra winches and/or extra crew members. People start tripping over each other. Simplicity is good.
I think it's time to move the winches. I think the geometry of the lines running from the catbirds (or stern cleats) to the cabintop winches and a wheel in the cockpit makes for an awfully small cockpit. Move the winches from the cabintop to the coamings and replace the starboard winch with another one for the halyards. You should be able to route the jib halyard to starboard with a block at the base of the mast.
how far back do the genoa tracks run? On the C25, they run all the way back to the rear cleats, allowing for an additional block to be mounted. Turn around that block, and back to the coaming mounted winches. I have pulled back the genoa block when flying wing-on-wing with good success. I haven't tried a spin yet.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i> <br />Don, which kind of cleat do you use for the spinny sheet, cam, horn, ???
Paul <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Horn cleat. I sail with no particular destination so I cleat my sheet then sail to an apparent wind angle which means, for the most part, once I cleat the sheet I'm adjusting the boats heading if the wind shifts rather than adjusting the spinnaker trim.
Ok, I think I have all the hardware (new cam cleats to mount on the coamings)
Reading up on flying an Aspin, think I have it down.
So far my plan is to fly it inside the forestay. So I'll use the Jib halyard (which is aft of the furler) to hoist the shute.
I have a shackle on the tang of the forestay plate at the bow and will attach a block there for the tack.
Will run a line from the tack through the block and to the port winch.
Continuous sheet will run from the clew to the block on the catbird seat and down to the new cam cleat.
I was going to remove the core of the sheet from the clew to the block when the sail is pulled tight (ie shortest length from clew to block) to reduce the weight of the sheet at the clew.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i> <br />So far my plan is to fly it inside the forestay.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I find it much easier to gybe the spinnaker outside the forestay, as it's a lot of sail to stuff through the smaller foretriangle.
The question is do they consider 2005 to be a 'later model', Our masthead casting looks really similar to the one on the CD site, but actual experience wins on this one.
