 Aft Stay Modifications
Response Posted - 04/13/2007 :  21:57:41  Show Profile  Visit britinusa's Homepage
Joseph, going back to my idea of a pair of backstays: Out of the way, shared low load to each outside edge of the catbird seats, easy pelican shackle connections, the masthead is more than wide enough for two, out of the way for bimini, no need for hole in bimini to accomodate the wires, clear of the wheel, and easy to setup tensioner for tuning.
Paul.
frogger
Response Posted - 04/14/2007 :  07:10:10  Show Profile
Thanks, Paul, and all. Now all I have to do is decide on the setup to use. Unfortunately I will have to put mods away while I "heal" from a very nasty fall down a high flight of stairs (15 steps) onto a hard landing. Lucky in that I only broke ribs and ego. As they say, I will mull this over and make modifications as soon as I can. Bummer, azaleas are blooming, lake is up, wind and weather are good...
welshoff
Response Posted - 04/16/2007 :  10:30:51  Show Profile
FYI - Here is a link to a [url="http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=11434&SearchTerms=split"]backstay modification[/url]. Just an option.
SEAN
Response Posted - 04/16/2007 :  16:55:59  Show Profile
I seen on those ocean raceing boats they add a extention off the top of the mast ,like 3' off the back to have a bigger roach on the main .
that might work ?
just thinking out loud not ment for jarrett
Edited by - SEAN on 04/16/2007 17:01:54
